http://pcpartpicker.com/p/xvZX7P
He has all of the peripherals, he has a budget of $1000 give or take some.
Changes/Suggestions?
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
https://linustechtips.com/topic/423573-build-for-a-friend/
Get a 390 instead of the 970, it performs better than the 970 in almost all games at 1080p and 1440p
Echelon Mk 2.11
  • Processor: Intel Core i5-6500
  • Cooler: Cryorig H7 (With a 120 mm Thermaltake Riing RGB)
  • Motherboard: MSI B150M Bazooka Plus
  • Memory: 16 (2x8) GB DDR4 Kingston HyperX Fury (Black)
  • Video Card: Sapphire NITRO R9 390 (Stock)
  • Storage:  1 TB Western Digital Blue
  • Power Supply: 520 W Seasonic M12II Evo (with custom extensions and cable combs)
  • Casing: NZXT S340 Elite (Matte Black)
  • Fans: 2x 120 mm & 3x 140 mm Thermaltake Riing RGB
  • Display: 22 " LG Flatron L227WTG-PF LCD (OCed to 76 Hz)
  • Keyboard: Logitech K120
  • Mouse: Logitech G402 Hyperion Fury
  • Mousepad: SteelSeries QcK
  • Operating System: Windows 10 Pro (64-bit)
https://linustechtips.com/topic/423573-build-for-a-friend/#findComment-5687764
Why not the i5 4690k?
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/423573-build-for-a-friend/#findComment-5687783
Let me flag the problems,
you get a unlocked motherboard with a locked CPU, If you don't have any plans on overclocking, the stock cooler is perfectly fine.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor  ($229.99 @ SuperBiiz)
Motherboard: MSI Z97-Gaming 3 ATX LGA1150 Motherboard  ($111.98 @ Newegg)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card  ($338.49 @ SuperBiiz)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($54.99 @ Micro Center)
Total: $938.43
Generated by PCPartPicker 2015-08-05 04:28 EDT-0400
Something like this should suffice, I can understand if he doesn't want to choose AMD card, just change the 970 to an AMD one if he wants future proof, (390)
https://linustechtips.com/topic/423573-build-for-a-friend/#findComment-5687790
Here's a pretty bitchin part list i put together,
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler  ($25.98 @ OutletPC)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1866 Memory  ($46.99 @ Newegg)
Storage: Kingston SSDNow V300 Series 120GB 2.5" Solid State Drive  ($48.99 @ NCIX US)
Storage: Seagate Barracuda 2TB 3.5" 7200RPM Internal Hard Drive  ($71.89 @ OutletPC)
Video Card: MSI Radeon R9 390 8GB Video Card  ($329.98 @ SuperBiiz)
Case: Raidmax Vortex ATX Mid Tower Case  ($38.99 @ SuperBiiz)
Power Supply: Cooler Master VSM 650W 80+ Gold Certified Semi-Modular ATX Power Supply  ($66.99 @ Newegg)
Total: $971.78
Generated by PCPartPicker 2015-08-05 04:35 EDT-0400
https://linustechtips.com/topic/423573-build-for-a-friend/#findComment-5687808
Also going to need a wifi adapter probably. This is the one i use for all pcs i build,
http://pcpartpicker.com/part/tp-link-wireless-network-card-tlwdn4800
https://linustechtips.com/topic/423573-build-for-a-friend/#findComment-5687814
he doesnt want to overclock
https://linustechtips.com/topic/423573-build-for-a-friend/#findComment-5687823
He will be using an ethernet cable
https://linustechtips.com/topic/423573-build-for-a-friend/#findComment-5687840
the future proofing option would be to get it anyway. Just cause he doesn't want to know, doesn't mean there isn't the possibility in the future. And if it ever starts showing its age in the future he could overclock it then before having to shell out cash for new components.
https://linustechtips.com/topic/423573-build-for-a-friend/#findComment-5687844
I see your point. I will tell him about this. On another note, so far he wants the GTX970 G1 because of its overclocking opportunities and power consumption/heat compared to the R9 390 and he also likes Nvidia features. I will have him look at both sides from AMD and Nvidia perspectives.
https://linustechtips.com/topic/423573-build-for-a-friend/#findComment-5687863
Just make sure he doesn't go Nvidia because he believes the power bill is twice as much BS or all the 90 degree BS.
https://linustechtips.com/topic/423573-build-for-a-friend/#findComment-5687893
No he doesn't care about the cost of power consumption. If going nvidia can spare him an extra 50$ on a power supply + overclocking advantages however that would be a benefiting factor.
https://linustechtips.com/topic/423573-build-for-a-friend/#findComment-5687903
This here. I prefer the green team and normally would have chosen a 970, but some people here are extremely anal about that
https://linustechtips.com/topic/423573-build-for-a-friend/#findComment-5687905
Well I do admire the green team compared to the red team however I am not a fanboy because I consistently have heated discussions supporting both amd and nvidia. Anyways, I tend to stick with nvidia due to adaptive vsync, geforce experience, and the new MFAA for 900 series, which I never new about even before I bought my card. I was upset when nvidia pulled that 970 memory con but that doesn't change the other factors. Thats just my opinion anyways :P
https://linustechtips.com/topic/423573-build-for-a-friend/#findComment-5687921
Total: $938.43
I made a revised build based on your suggestions - http://pcpartpicker.com/p/yhTd7P
I think that is very solid.
https://linustechtips.com/topic/423573-build-for-a-friend/#findComment-5687936
Probably don't get the gaming 3. I've had 3 data ports go dead on me and its very temperamental sometimes for no reason eg.(ram won't be working for some reason so taking it out and putting it back in fixes it) I didn't read the reviews for it before I got it and I believe I base like a 2.7 star rating on amazon...
https://linustechtips.com/topic/423573-build-for-a-friend/#findComment-5687954
Why not send it to them. If your board turned out faulty doesn't mean everyone's well. And don't relie on amazon ratings, professional ratings are better as people are usually more likely to place a review if they have a issue than if they had a good experience.
https://linustechtips.com/topic/423573-build-for-a-friend/#findComment-5688007
And from which supplier in amazon did you check? Seems fine here http://www.amazon.com/Gigabyte-GA-Z97X-GAMING-Gaming-Networking-Motherboard/dp/B00K2RQDXY/ref=sr_1_1?ie=UTF8&qid=1438767173&sr=8-1&keywords=gaming+3 .
https://linustechtips.com/topic/423573-build-for-a-friend/#findComment-5688011
