Networking questions (need help)
Solved by Lord_Karango17,
ok but which is better wireless or power line? also is a ethernet switch like a hub? if not what do they do?
I think powerline would be better in you case, as the router is in the garage, and from what I'm understanding, it would be a pain to move.
Speed wise, wireless isnt too bad, but when you add thick walls, and interference, it will slow down significantly.
Yeah, I'm pretty sure a switch is just like a hub.
