Networking questions (need help)
Go to solution Solved by Lord_Karango17,
ok but which is better wireless or power line? also is a ethernet switch like a hub? if not what do they do?
I think powerline would be better in you case, as the router is in the garage, and from what I'm understanding, it would be a pain to move.
Speed wise, wireless isnt too bad, but when you add thick walls, and interference, it will slow down significantly.
Yeah, I'm pretty sure a switch is just like a hub.
i didnt mean it in a bad way :P, i meant i need me some.
do you mean the ones that get wired into the wall?
or one of them lan splitter things, im not that big on networking, my area is vdsl.
yeah, the ones wired into the wall.
http://kevinsnyder.info/album/homes/mi.livonia.2003-current/voip_wiring.phone_outlet_addition.2006/slides/2006-01-16.adding.phone.catv.lan.wall_outlet.7.all.cables_run.connected.livonia.mi.us.jpg
Cant tell you the amount of money, and time I would have saves I i had those in every room... Living in 100+ year old houses has its disadvantages xD
Cpu: Ryzen 2700 @ 4.0Ghz | Motherboard: Hero VI x370 | Gpu: EVGA RTX 2080 | Cooler: Custom Water loop | Ram: 16GB Trident Z 3000MHz
PSU: RM650x + Braided cables | Case:  painted Corsair c70 | Monitor: MSI 1440p 144hz VA | Drives: 500GB 850 Evo (OS)
Laptop: 2014 Razer blade 14" Desktop: http://imgur.com/AQZh2sj , http://imgur.com/ukAXerd
100 Mbps.
so you got 100 Mbs when connected to the router via lan?
via ethernet
Ok, so the wifi is the problem then, because the router seems fine if you are getting the advertised speeds via ethernet. if there are power outlets in your garage, then have a look at powerline, as it allows you to send the data through cabling that is already in your house (im unsure about the exact details, but I remember linus doing a video on the topic)
ok could you send that link?
Ok, so the wifi is the problem then, because the router seems fine if you are getting the advertised speeds via ethernet. if there are power outlets in your garage, then have a look at powerline, as it allows you to send the data through cabling that is already in your house (im unsure about the exact details, but I remember linus doing a video on the topic)rought
also i have a big house and how am i going to get ethernet to my office?
prepare for video bomb (he made more videos on the topic than i realized)
ok so i can get powerline and hook up a switch and hook it up to all my computers and it will be faster than wifi? thanks!
