A good affordable mouse?
Go to solution Solved by TwOne,
I think the Deathadder is kind of overpriced for what it is (especially the Chroma version).
I would say the Roccat Savu and the CM Storm Recon are really underrated mice, but they have a nice price, great sensor and lots of functions that many more expensive mice also have.
Can someone recommend me a good mouse that is good yet not overpriced? I would prefer a mouse with a cord as I once used a wireless mouse that would randomly disconnect for no apparent reason but if you know one that is good please do list it.
-I live in Canada if that would help give more discrete links
https://linustechtips.com/topic/421824-a-good-affordable-mouse/
CoolerMaster Xornet. $20 last time I checked.
https://linustechtips.com/topic/421824-a-good-affordable-mouse/#findComment-5665238
Honestly I think if you're going to buy a mouse, you buy a high quality one, seeing as they're pretty cheap nowadays (eg. G502, Deathadder).
CPU: i5-4690k GPU: 280x Toxic PSU: Coolermaster V750 Motherboard: Z97X-SOC RAM: Ripjaws 1x8 1600mhz Case: Corsair 750D HDD: WD Blue 1TB
How to Build A PC|Windows 10 Review Follow the CoC and don't be a scrub~soaringchicken
https://linustechtips.com/topic/421824-a-good-affordable-mouse/#findComment-5665351
When you say Deathadder are you referring to any specific type? ie chroma, Razer DeathAdder Ergonomic or USA 2013
From what I searched up it goes from the original to 2013 version to chroma, so is the Ergonomic the original or is this another version?
https://linustechtips.com/topic/421824-a-good-affordable-mouse/#findComment-5667541
CPU: Ryzen 5 3600X            | Cooler: Deepcool AK400  | Motherboard: B550 Elite AX V2  | Storage: Samsung 980 Pro 1TB  |
RAM: Corsair Vengeance 16GB   | GPU: MSI RTX 3060 Ti    | Case: NZXT H440 (Red/Black)    | PSU: EVGA 650W G2             |
https://linustechtips.com/topic/421824-a-good-affordable-mouse/#findComment-5668085
I guess chroma, but not really sure what the ergonomic is.
https://linustechtips.com/topic/421824-a-good-affordable-mouse/#findComment-5668367
Laptop: Intel Core i5-4200H, 8GB RAM, 750GB HDD, GeForce 840M
Desktop: Intel Core i3-6100, 8GB RAM, 750GB HDD, GeForce GTX 750 Ti
https://linustechtips.com/topic/421824-a-good-affordable-mouse/#findComment-5669554
Depends on what you want, wired is probally the best option but if your looking for wireless the logitech M560 mouse for $25 on amazon is amazing for the price. Also amazing battery life, if you want a cheaper version go for the silver one, which in my opinion looks better. But its your choice.
http://www.amazon.com/Logitech-Wireless-Mouse-M560-Windows/dp/B00DR8LB4Q
https://linustechtips.com/topic/421824-a-good-affordable-mouse/#findComment-5670025
That's a really nice find, I'll just wait till the Roccat Savu comes back in stock on that site since else where its about 60 dollars which would make it 20 dollars less than the chroma.
https://linustechtips.com/topic/421824-a-good-affordable-mouse/#findComment-5672914
yeah it probably is, but I was just using it as an example. Although, I'm probably going to buy one soon, I just like the general look of it and the simplisticness (not a word) as opposed to a g502 with macros and all that jazz.
https://linustechtips.com/topic/421824-a-good-affordable-mouse/#findComment-5674063
