F1 key is stuck.
Solved by Alpha17x,
Firstly
You could use Autohotkey and make a macro.
f1::Return
The macro would be active (and thus f1 disabled) as long as Autohotkey was active in your system tray
Secondly
You could also use Sharpkeys to remap it / turn it off
Open Sharpkeys, Click add.
On the left side click the 'type key' button and press F1
On the right hand side select 'Turn Key Off' then click okay.
Write to Registry, reboot. It should not do anything anymore.
To get it back just turn it back on and write to registry.
**Consider backing up your registry before committing any changes**
