i just want another persons opinion on my future pc
CPU: Intel Core i3-4160 Haswell Dual-Core 3.6GHz
Motherboard: GIGABYTE GA-H97-D3H LGA 1150 Intel H97
Video card: MSI R9 380 GAMING 4G Radeon R9 380
RAM: HyperX Fury Black Series 8GB 240-Pin
Hard drive: Seagate Hybrid Drive ST1000DX001 1TB
SSD: Crucial BX100 CT250BX100SSD1 2.5" 250GB SATA 6Gbps
Case: Rosewill CHALLENGER - Black Gaming ATX Mid Tower Computer Case
Power Supply: Cooler Master Elite V2 - 550W
Optical Drive: Asus DVD-RW Bulk Drive
Case Adapter: BYTECC BRACKET-125 HDD/SSD 1 x 2.5” Drive to 3.5” Bay Metal Mounting Kit
Operating system: Windows 8
All help is apreciated and if you have any ideas  to improve this thank you (i will be upgrading my CPU)
https://linustechtips.com/topic/419412-need-help/
This can be improved depending on your budget :P
https://linustechtips.com/topic/419412-need-help/#findComment-5637038
The cpu may be a bottleneck so here is what you should do.Get an normal hdd because ssdh sucks anyway and go down to a 128 gb ssd and get one from adata the sp900,it's better.If you save enough money step to an i5 and you should be good
Beware of him that is slow to anger; for when it is long coming, it is the stronger when it comes, and the longer kept. Abused patience turns to fury.
https://linustechtips.com/topic/419412-need-help/#findComment-5637073
And in this case get an intel i5 4460
https://linustechtips.com/topic/419412-need-help/#findComment-5637078
