LED Strips for TV
Solved by W-L,
Ultimately, I only need RGB leds that I can change the color of manually. While the LEDs that sync with the content on your tv is cool, it seems a bit overkill.
A set like theses would work perfectly and suit your needs:
Featured Topics
frostymelts ·
Posted in Troubleshooting0 -
1
RevGAM ·
Posted in Custom Loop and Exotic Cooling3 -
JakubR88 ·
Posted in Power Supplies6 -
1
2
4
4
play_circle_filled
Latest From Linus Tech Tips:
I Am Not Buying A Super Computer - WAN Show May 3, 2024
