Hi !
so i wanted to get a water cooler but i am on a tight budget so 80 euro's max.
i use a fx 8350 so its am3+ and i use a define R5 (soon) so it CAN be a dual rad.
so i was looking at the seidon 120V and H55/H60 but i don't know a hole lot of water cooling so can you guys help me with this?
thanks
On 11/19/2014 at 2:14 PM, Syntaxvgm said:
You would think Ubisoft would support the Bulldozer based architectures more given their digging themed names like bulldozer, Piledriver, Steamroller and Excavator.
https://linustechtips.com/topic/416759-budget-water-cooling/
raijintek triton?
i like this one, il have a look at it
https://linustechtips.com/topic/416759-budget-water-cooling/#findComment-5605105
