I've been looking for a large mouse pad, or rather a deskpad since the size I need is at least 35 x 15 inches.
I found this, but the quality seems pretty terrible; the cloth on these types of pads seems to curl off.
http://www.ebay.ca/itm/Extra-Large-Size-Optical-Mouse-Pad-Wide-Mat-for-Gaming-Gamer-LMSPZ-1-/151071672169?pt=US_Mouse_Pads_Wrist_Rests&hash=item232c92c769&_uhb=1
Can anyone recommend a large mousepad for around the $25 price point? Preferably with shipping to Canada.
https://linustechtips.com/topic/41674-help-me-find-a-mousepad/
Get a Steelseries Qck, I believe they have a large version. You can get it from NCIX Canada.
Case-NZXT H440 | Motherboard-Gigabyte Z77X-UD3H | RAM-Kingston HyperX Blue 2x8GB 1600MHz | CPU-Intel 3770K @ 4.3GHz at 1.215v | Heatsink-Coolermaster Hyper212 Evo | GPU-EVGA GTX660 SC | SSD-MX200 250GB | HDD-Seagate Barracuda 3TB | PSU-EVGA GS650
Mouse-Logitech G600 | Keyboard-Ducky Shine 3 MX Blue. white backlight | Headphones-Audiotechnica ATH-M50s. Beyerdynamic DT990
https://linustechtips.com/topic/41674-help-me-find-a-mousepad/#findComment-541113
The large version is only 17 inches wide if I'm not mistaken, I need a much wider surface. (Reason being: my desk scratches really easy due to the keyboard and mouse movements)
https://linustechtips.com/topic/41674-help-me-find-a-mousepad/#findComment-541131
Just get the Razer Goliathus XL or whatever it's called, Go for whats cheaper tho! :D
Intel i7-2600K @ 4,5GHz | EVGA GeForce GTX 780 w/EKWB Copper Waterblock | Kingston HyperX blu 16GB @ 1600 MHz | Phanteks Enthoo Primo | MSI Z77A-GD65 | CM M1000 Silent Pro | Samsung 840 Pro 128GB | BenQ XL2420T 120hz | Logitech G710+ | Razer Deathadder 2013 -
- XSPC Raystorm CPU Waterblock | XSPC RX360 Radiator | EKWB EK-FC Titan GPU Waterblock -
https://linustechtips.com/topic/41674-help-me-find-a-mousepad/#findComment-541145
http://www.amazon.com/XTracPads-Ripper-XXL-Desktop-Gaming/dp/B000HTDBWI
Tada! Some peeps on OCn were recommending it. I'd probably go with the Mionix one though ;)
export PS1='\[\033[1;30m\]┌╼ \[\033[1;32m\]\u@\h\[\033[1;30m\] ╾╼ \[\033[0;34m\]\w\[\033[0;36m\]\n\[\033[1;30m\]└╼ \[\033[1;37m\]'
"All your threads are belong to /dev/null"
| 80's Terminal Keyboard Conversion | $5 Graphics Card Silence Mod Tutorial | 485KH/s R9 270X | The Smallest Ethernet Cable | Ass Pennies | My Screenfetch |
https://linustechtips.com/topic/41674-help-me-find-a-mousepad/#findComment-541146
The Sargas comes down to $30 with tax included, not a bad price for something that is going to cover my entire desk. The Razer XL is more than $40 which is out of my range unfortunately.
Thanks for the friendly responses btw guys, ;)  I've asked for product recommendations on other forums before where you're told to "go and do a Google search."
https://linustechtips.com/topic/41674-help-me-find-a-mousepad/#findComment-541161
This one doesn't ship to Canada, and yeah I'm leaning toward the Mionix since I live near the NCIX store.
https://linustechtips.com/topic/41674-help-me-find-a-mousepad/#findComment-541170
