Graphics Card For 100
Go to solution Solved by manikyath,
100 what? currency and location? :D
100 bottlecaps offcourse :P
on topic: 750 or 750Ti
SNIP
https://linustechtips.com/topic/416561-graphics-card-for-100/#findComment-5602510
Can you wait a little while and expand your budget?  That's what I would advise at least, save and get a better one.
CPU: i7-4770k @4.8ghz---Motherboard: Asus Sabertooth z97---Ram 32gb Corsair Vengeance---GPU: 2 EVGA GTX 980 4gb way sli---Case: Corsair 600T White---Storage: 500gb 850 Pro & WD Black 4tb---PSU: Corsair RM1000
https://linustechtips.com/topic/416561-graphics-card-for-100/#findComment-5602522
Preferably € But Dollars Work Too
How does that work? :P
750ti but you can get good deals on used cars like the 7970 above, great card
https://linustechtips.com/topic/416561-graphics-card-for-100/#findComment-5602541
do not get the 750.
3 tips to have a good time on the LTT forums | 1. When you reply to someone please quote them | 2. Please follow your threads | 3. Follow the C.o.C
If you follow these 3 tips you should have a blast.
i'm rather proud of this for some reason. http://imgur.com/6ttS5XZ
https://linustechtips.com/topic/416561-graphics-card-for-100/#findComment-5602598
750 Ti would be great at this pricepoint. Also you should consider upgrading to 8GB RAM while the stuff is dirt cheap. It's about 40% cheaper than it was this time last year.
I don't call it dirt cheap because it's been way too overpriced for years..
https://linustechtips.com/topic/416561-graphics-card-for-100/#findComment-5603961
