I could suggest upping the PSU to a 750W, 650W would be cutting it close, but its fine... i think.
Heavy Editing? Like Freelancer photoshop/digital imaging or just Light Editing? Like making things just for fun
(NOW)War Horse:
CPU: AMD FX-6300 | Motherboard: MSI 970A-G43 | RAM: Corsair Vengeance Dual Channel 8GB 1600Mhz | GPU: MSI R7790 | Case: Dazumba D-Vito 903 | HDD 1 & 2: Seagate 1TB and Seagate 500GB | PSU: Corsair CX600
(WAS)Old Coop:
CPU: Intel C2D E7500 | Motherboard: Gigabyte G31M-ES2L | RAM: V-Gen 4GB Dual Channel | GPU: Galaxy GT210 | Case: Power-Up ??? | HDD: Seagate 500GB | PSU: Power-up 500W
MyAnimeList Profile | Heaven Society | HEIL THE MIGHTY AND POWERFUL LINUS | My Blog 'Unfinished Pieces' | Code of Conduct
mostly photoshop and some video editing. that's it
Get 2 390Xs and a 800W PSU for overclocking. Radeon cards scale better in Crossfire and also have more than double the VRAM.
7gb is still more than enough for one monitor
with the 970s he's getting 3.5, 2 cards DO NOT DOUBLE the VRAM.
If you won't OC then get the i7 4790 non k version. And I'd rather spend on a single 980ti than on two 970s as vRam will be limited and not all games are optimised for SLI.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
http://pcpartpicker.com/p/zKB7bv + mouse: Razer Deathadder 2013 edition (already have it)
how long do you think this will last (i plan to play every* game on ultra*)
i won't do any OC on cpu or gpu.
If I were you I'd get 1 980Ti, not 2 970's in SLI, because 1 980Ti will perform the same, but you'll have less noise/heat and avoid potential issues with SLI.
Also if you plan on doing no overclocking what so ever, why not get a non -k sku CPU, and get a H97 mother board? That will save you some money and you'll get the same benefits, Z97 is for overclocking mainly, and if you get a single 980Ti you wont need the Z97 for SLI either. You could also save money on a good air cooler because you wont be overclocking
i5 4690k | GTX 980Ti G1 Gaming | 16GB RAM | MSI Z97 Gaming 7 | NZXT Kraken X61 | 850 EVO 250GB x2  | 1TB 850 Evo NZXT Noctis 450 | EVGA 750W 80+ Gold
 Ducky Shine 3 TKL (Browns) | LG 34UC87C | Logitech MX Master ATH-M50x's + DT990 Pro's
i may oc in the future
You clearly said I won't OC in the original post, please make it clear that you will OC in the future in the post so that users don't get confused.
Ram doesn't stack when in SLI.
He meant he will overclock in the future, but he seemed to have not made it clear in the original post.
He can just download more RAM :D
yet nobody has answered the question: how long do you think it will last
Games depend on the GPU, not CPU so you are fine with an i5 for a long time. The i5 2500K is still among the best gaming CPUs.
That's a answer that can only be answered by you, I still have a computer with a gt 210 that I consider to be sufficient. As a rough guess I expect it to run games around high settings for some good time (e.g 3-4 years), but you will run into vRam issues as the 970 has 3.5 GB only eventually.
it depends on how long you are willing to use. it.
nothing is future-proof.
Recovering Apple addict
ASUS Zephyrus G14 2022
CPU: AMD Ryzen 9 6900HS GPU: AMD r680M / RX 6700S RAM: 16GB DDR5
Exactly. This is why getting a single more powerful card (980 TI/Fury X) or 390X CF is better.
http://pcpartpicker.com/p/3r6PkL
Yeah that's better, a 980Ti will let you play ever game on ultra for a decently long while, especially seeing as you're using a 1080p monitor, and you'll get a good use of the 144Hz on it because the 980Ti will be able to deliver that kind of performance.
Then in the future you can still do some nice overclocking.
A word of caution though, a much higher % of people using the Gigabyte G1 980Ti have complained about loud coil whine then other versions of the 980Ti. Personally mine has been perfect for me, and I don't get any coil whine, but it's something to keep in mind, because some retailers wont even let you return it if it has bad coil whine. So you can either take the risk, or pick out another cooler design for the 980Ti
