Is the NF-a15 much better?
Basically the same.
https://linustechtips.com/topic/414134-best-noctua-case-fan/#findComment-5571698
Ok. I proberly will go for the a15 as it has a slightly bigger fan for £1 more.
The difference is the mounting holes and not so much the fan size or performance.
https://linustechtips.com/topic/414134-best-noctua-case-fan/#findComment-5571731
