Will the NH-D15 fit in this build with no problems. I will be swapping out the normal fans for the corsair ones due to the normal ones being ugly.
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor (£177.00 @ Amazon UK)
CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler (£65.46 @ CCL Computers)
Thermal Compound: Arctic Cooling MX4 4g Thermal Paste (£4.69 @ Amazon UK)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard (£99.98 @ Amazon UK)
Memory: Corsair Vengeance Pro 8GB (2 x 4GB) DDR3-1600 Memory (£42.87 @ Ebuyer)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£39.00 @ Amazon UK)
Video Card: MSI GeForce GTX 980 Ti 6GB Video Card (£559.99 @ Dabs)
Case: NZXT Noctis 450 ATX Mid Tower Case (£98.94 @ Scan.co.uk)
Power Supply: XFX PRO Black Edition 850W 80+ Gold Certified Fully-Modular ATX Power Supply (£89.99 @ Scan.co.uk)
Case Fan: Corsair SP140 49.5 CFM 140mm Fan (£10.50 @ Scan.co.uk)
Monitor: LG 24GM77 144Hz 24.0" Monitor (£203.62 @ Amazon UK)
Total: £1402.54
Generated by PCPartPicker 2015-07-24 01:09 BST+0100
https://linustechtips.com/topic/414117-will-this-cpu-cooler-fit/
indeed it will, that case has room for a cooler of 180mm high.
Gpu: MSI 4G GTX 970 | Cpu: i5 4690k @4.6Ghz 1.23v | Cpu Cooler: Cryorig r1 ultimate | Ram: 1600mhz 2x8Gb corsair vengeance | Storage: sandisk ultra ii 128gb (os) 1TB WD Green | Psu: evga supernova g1 650watt | Case: fractal define s windowed |
https://linustechtips.com/topic/414117-will-this-cpu-cooler-fit/#findComment-5571277
It wont be too close to your gpu but idk about your ram
the ram will be fine, it will  clear the top of it.
https://linustechtips.com/topic/414117-will-this-cpu-cooler-fit/#findComment-5571291
Will it support my ram?
Yep!
(Aytex and I do the same thing. :P )
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
https://linustechtips.com/topic/414117-will-this-cpu-cooler-fit/#findComment-5571312
what do we do?
Camp the recent topics section.
I'm a student so I don't have all the time in the world, but I do it when I can. :P
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/414117-will-this-cpu-cooler-fit/#findComment-5571358
im on summer break. When I was at school on LTT I couldn't focus on my work and my grades started failing
https://linustechtips.com/topic/414117-will-this-cpu-cooler-fit/#findComment-5571362
Lucky...
Stille (Desktop)
Evoo Gaming 15"
https://linustechtips.com/topic/414117-will-this-cpu-cooler-fit/#findComment-5571373
don't change the noctua fans please......... if you think their ugly give me them please lol
Early 2020 Build : Intel i7 8700k // MSI Krait Z370 // Corsair LPX 8x2 16GB // Aorus 5700 XT // NZXT H500
Early 2019 Build : Ryzen 2600X // Asus Tuff X470 // G.Skill Trident Z RGB 8x2 16GB // MSI RTX 2070 // NZXT H500
Late 2017 Build : Intel i7 8700k // Asus Prime Z370-A // G.Skill Trident Z 8x2 16GB // EVGA GTX 1080 Ti  // NZXT S320 Elite
Late 2015 Build : Intel i7 6700k // Asus Maximus VI Gene Z170 //  Corsair LPX 8x2 16GB // Gigabyte GTX 970 // Corsair Air 240
https://linustechtips.com/topic/414117-will-this-cpu-cooler-fit/#findComment-5571386
I know this is a bit unrelated but you have been amazing so far. What is the best noctua case fan, I want to buy 2 140mm fans and which is the best. They will be hidden so colour is not a problem lol.
https://linustechtips.com/topic/414117-will-this-cpu-cooler-fit/#findComment-5571575
