Strange leak?
The fitting I just attached an image of came with the res. In the manual it said to use where it was an inlet but assumed since I was doing a top inlet it would be different?
So if that fitting's o-ring wasn't slipping it would work?
And hopefully @EK Luc will know what is happening-all products are EKWB!
Hi,
On your top inlet you must use the extender that you showed in the picture above since the port is recessed. Then you will screw your compression fitting on.
The leak appears because the compression fitting can't sit correctly in the port since it's wider than the recessed port.
So in the end your top should be a combination of Top + Extender + Compression fitting.
This way you should be good to go without leaks. ![]()
Let us know how it turns out.
