I'm not quite sure what you mean?
It says the max value on your memory usage was 1582 mb, your cards have 3GB of vram..
his idle memory usage is 900MB
The Images are my cards at idle
This I know already
what resolutino do u play in. what game. what ingame settings
Mostly 1080 at ultra but when Im at the desktop just browsing the interwebs it chews alot more than it should
Track your Vram usage using MSI AB and check it with GPU-Z just to be fully sure.
AMD Phenom II B55 Quad / unlocked dual core 4.3ghz CB R15 = CB 422
XFX R9 390 8GB MY RIG: http://uk.pcpartpicker.com/p/MVwQsY
Fastest 7770 on LTT . 3rd Fastest Phenom II Quad on LTT
PCSX2 on AMD CPU? http://linustechtips.com/main/topic/412377-pcsx2-emulator-4096x2160-amd-phenom-ii/#entry5550588
This I know already
What's running in the background?
So you're maxing out the vRAM in games? If you're not, then it's not the vRAM causing the issue.
Do you have multiple monitors and Windows 8.1 (or possibly Windows 10; I haven't seen reports of 10's vRAM usage)? If so, then while a little high, it's not unheard of. With a 1080p main screen and a 768p second monitor and windows 8.1 Pro, I use somewhere between 400-700MB of vRAM without really doing anything on the desktop.
I have finally moved to a desktop. Also my guides are outdated as hell.
THE INFORMATION GUIDES: SLI INFORMATION || vRAM INFORMATION || MOBILE i7 CPU INFORMATION || Maybe more someday
