Wall mounted PC
Go to solution Solved by TheKDub,
Yeah, well my sound card will be outside the case, so how do I get an EMI shield, becuase someone told me that leaving a sound card exposed will open it up to EMI?
If you're mounting the PC on a wall, it's not going to be in a case, meaning the EMI from the components can go wherever it wants instead of being at least partially blocked by the case.
Hey guys! I was just wondering about something. So, I'm going to get a wall mounted PC, and I'm going to have a PCI extension to all the add on cards in my system(GPU, sound card, etc.). Now, my theory is that my sound card and GPU will have less EMI, therefore increasing performance(this will effect the GPU very slightly if not at all; my sound card is the card that'll benefit the most to this). So, is this theory true? Thanks in advance for your help, time and effort!
https://linustechtips.com/topic/411696-wall-mounted-pc/
I highly doubt it will "increase GPU performance" at all, and the sound card will probably be exposed to more EMI due to it being unshielded by a case.
If anything I'd guess it would decrease GPU performance over time due to the lack of dust protection.
https://linustechtips.com/topic/411696-wall-mounted-pc/#findComment-5541339
that has nothing to with your sound card, if any keep your speakers away and test it and it still shouldn't matter at the end of the day.
AMD 5000 Series Ryzen 7 5800X| MSI MAG X570 Tomahawk WiFi | G.SKILL Trident Z RGB 32GB (2 * 16GB) DDR4 3200MHz CL16-18-18-38 | Asus GeForce GTX 3080Ti STRIX | SAMSUNG 980 PRO 500GB PCIe NVMe Gen4 SSD M.2 + Samsung 970 EVO Plus 1TB PCIe NVMe M.2 (2280) Gen3 | Cooler Master V850 Gold V2 Modular | Corsair iCUE H115i RGB Pro XT | Cooler Master Box MB511 | ASUS TUF Gaming VG259Q Gaming Monitor 144Hz, 1ms, IPS, G-Sync | Logitech G 304 Lightspeed | Logitech G213 Gaming Keyboard |
PCPartPicker
https://linustechtips.com/topic/411696-wall-mounted-pc/#findComment-5541475
Wait, what? My sound card gets more EMI by leaving them unhielded? Well then, are there any buy able EMI resistant shields for sound cards? There must be, because then how would DACs keep out EMI. So, where can I buy shields from EMI?
https://linustechtips.com/topic/411696-wall-mounted-pc/#findComment-5549168
I said that it will most likely not increase GPU performace, but it'll make it worse due to dust? Well, couldn't you just clean out the GPU fan when the PC's turned off?
https://linustechtips.com/topic/411696-wall-mounted-pc/#findComment-5549180
DACs are more protected from EMI because they are outside of the computer case.
The built in sound cards of most motherboards now adays are perfectly fine for normal use anyways, imo sound cards are not worth it, if anything get an external dac.
https://linustechtips.com/topic/411696-wall-mounted-pc/#findComment-5549194
Yes you could just clean out the GPU fans and such, but do you really want to have to keep doing that every couple of weeks or months to keep it from being clogged by dust?
https://linustechtips.com/topic/411696-wall-mounted-pc/#findComment-5549199
https://linustechtips.com/topic/411696-wall-mounted-pc/#findComment-5549205
https://linustechtips.com/topic/411696-wall-mounted-pc/#findComment-5549259
I think you're overestimating how much EMI a case blocks. Distance is the greatest factor.
https://linustechtips.com/topic/411696-wall-mounted-pc/#findComment-5549292
