Hi, Im going to build The Rig next week, need help in selecting a CPU cooler. Water Or Air?  used for VFX, video editing & little of gaming.
Motherboard
Asus X99-e WS
Processor
Intel i7 5960X
Cabinet
 Corsair Obsidian Series 750D
Corsair Hydro Series H80i or Hydro Series™ H100i GTX, But just scared/worried if there is a leak
or
Noctua NH-D14 , but that is huge hope it does not block somethings
Thanks
https://linustechtips.com/topic/410200-help-cpu-cooler/
With such a high end CPU go for a NZXT x61 Kraken. You'll have cooler temps then the corsair h100i. Most AIOs do note leak and the companies like corsair and NZXT replace parts if I recall correctly.
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
https://linustechtips.com/topic/410200-help-cpu-cooler/#findComment-5523888
Yeah they sometimes replace parts... it kinda depends TBH
CPU: i7-8700K I CPU Cooler: Noctua NH-D15 GPU: ROG Strix 1080 Ti MoBo: ROG Strix Z370-E RAM:  G.SKILL Ripjaws V Series 32GB (2 x 16GB)   PSU: CORSAIR HXi Series HX1000i Case: Corsair Air 540 Display: 24" 1920X1080p 144Hz ASUS - 27" 2560X1440p 144Hz Dell OS: Windows 10 Home 64bit
https://linustechtips.com/topic/410200-help-cpu-cooler/#findComment-5523968
i have an h100i and love it. id go water for sure. if you mount it exactly how the instructions say to and dont try and modify/tamper with it in any way you should be good to go. also if your really worried im pretty sure you could mount the rad on the bottom of the 750d so if it was to leak it would drip away from the important pieces. but again AIOs dont leak unless you screw with them and try and make them "work better"
https://linustechtips.com/topic/410200-help-cpu-cooler/#findComment-5523984
Thermalright Silver Arrow IB-E Extreme.
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
https://linustechtips.com/topic/410200-help-cpu-cooler/#findComment-5523993
water definitely water.
AMD 5000 Series Ryzen 7 5800X| MSI MAG X570 Tomahawk WiFi | G.SKILL Trident Z RGB 32GB (2 * 16GB) DDR4 3200MHz CL16-18-18-38 | Asus GeForce GTX 3080Ti STRIX | SAMSUNG 980 PRO 500GB PCIe NVMe Gen4 SSD M.2 + Samsung 970 EVO Plus 1TB PCIe NVMe M.2 (2280) Gen3 | Cooler Master V850 Gold V2 Modular | Corsair iCUE H115i RGB Pro XT | Cooler Master Box MB511 | ASUS TUF Gaming VG259Q Gaming Monitor 144Hz, 1ms, IPS, G-Sync | Logitech G 304 Lightspeed | Logitech G213 Gaming Keyboard |
PCPartPicker
https://linustechtips.com/topic/410200-help-cpu-cooler/#findComment-5524001
as long as you've got a warranty which I think it comes with one and didn't tinker/modify it they should.
https://linustechtips.com/topic/410200-help-cpu-cooler/#findComment-5524002
Croyorig r1 ultimate, almost half the price and performs as good.
Gpu: MSI 4G GTX 970 | Cpu: i5 4690k @4.6Ghz 1.23v | Cpu Cooler: Cryorig r1 ultimate | Ram: 1600mhz 2x8Gb corsair vengeance | Storage: sandisk ultra ii 128gb (os) 1TB WD Green | Psu: evga supernova g1 650watt | Case: fractal define s windowed |
https://linustechtips.com/topic/410200-help-cpu-cooler/#findComment-5525461
