Unfortunately I would have to a barer of bad news to tell you that 4K multi monitor set ups can't be achieved nowadays. Scaling in SLI above 2 cards isn't that good and 2 980ti or titan X cards can only handle 4K 60fps in one 4k monitor.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/409342-i-need-some-help-d/#findComment-5513435
For 4k you only need 2x 980 Ti's, 3 if you really want to be weird. 4 is worthless as you get terrible performance out of it.
No.
....He said 2 4K monitors m8. Even 4 980Tis won't be enough. Anyways, if he has the money, why the hell not?
https://linustechtips.com/topic/409342-i-need-some-help-d/#findComment-5513479
I don't think you understand what "no" means. Gaming on two monitors is pointless to begin with. Second of all, 4-way scaling on both SLI and CFX is trash. Third, the perform would be terrible.
https://linustechtips.com/topic/409342-i-need-some-help-d/#findComment-5513482
1. The OP asked for a setup that could run 2 4K monitors. Out of the choices he gave us, the 4x 980Ti is best.
2. Scaling is trash, but he asked between those two so I said which was best.
3. The performance would not be terrible. It would be better than 3x Titan X, his other option.
4. Look up 'Ad hominem'. I understand what no means, thank you very much.
https://linustechtips.com/topic/409342-i-need-some-help-d/#findComment-5513518
1. No, because scaling for those is shit
2. See above
3. Yeah it would be
4. Oh boy, someone that uses Latin argumentum. You must know eeeeeveeeeeeeeerything.  :rolleyes:
https://linustechtips.com/topic/409342-i-need-some-help-d/#findComment-5513526
2. See above
3. Yeah it would be
1. Titan X pretty much= 980Ti with 12GB VRAM. So 4 980Tis is better than 3 Titan Xs, or 980Tis.
2.'See Above'
3.'See above'
4. Just pointing out your amazingly pathetic debating techniques. 'Do you understand what no means'.
https://linustechtips.com/topic/409342-i-need-some-help-d/#findComment-5513546
Everything above 2way SLI is wasted Money.
And 2 Monitors for Gaming?
You should rethink that.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/409342-i-need-some-help-d/#findComment-5513563
2.'See Above'
3.'See above'
Okay precious snowflake, it seems you still don't understand bad scaling.
https://linustechtips.com/topic/409342-i-need-some-help-d/#findComment-5513570
The point is, due to aftermarket pre OC 980Tis, Titan X = 980Ti. Obviously having 4 of one GPU will result in better performance than having 3 of one GPU. Either that or I am an idiot and am not getting something about scaling.
https://linustechtips.com/topic/409342-i-need-some-help-d/#findComment-5513604
Four way scaling does not exist, you get as much or worse performance than three way scaling.
https://linustechtips.com/topic/409342-i-need-some-help-d/#findComment-5513612
You would not get worse performance... Also it exists to a tiny degree. I don't care if it is by 1FPS, or even 1point in fire strike, 4 way scaling DOES exist.
https://linustechtips.com/topic/409342-i-need-some-help-d/#findComment-5513629
