Hello guys
need your help to evaluate my OC.
Is the vcore much high? Will damage my CPU if used 24/7?
In bios setting is:
VCORE - 1.4500 Loadline MEDIUM.
Min: 1.44; Max(peak): 1.48; Avg: 1.44~1.46
NB vcore 1.110
My FSB is too high? I should lower the FSB and try to raise the multiplier?
CORE i5 4670K ASRock Fatal1ty KILLER 8GB CORSAIR VENGEANCE PRO  MSI GTX 770 7TEAM 550W
AMD FX6300 GA 990FXA-UD3 4.0 16GB G.SKILL TridentX  EVGA 9600 GT EVGA SN 750W G2
https://linustechtips.com/topic/408815-help-will-i-kill-my-cpu/
1.45v :o lower it. i would never go past 1.3v
"Sulit" (adj.) something that is worth it
i7 8700K 4.8Ghz delidded / Corsair H100i V2 / Asus Strix Z370-F / G.Skill Trident Z RGB 16GB 3200 / EVGA GTX 1080Ti FTW3 / ASUS ROG SWIFT PG279Q
Samsung 850 EVO 500GB & 250GB - Crucial MX300 M.2 525GB / Fractal Design Define S / Corsair K70 MX Reds / Logitech G502 / Beyerdynamic DT770 250Ohm
SMSL SD793II AMP/DAC - Schiit Magni 3 / PCPP
Old Rig
i5 2500k 4.5Ghz | Gigabyte Z68XP-UD3P | Zotac GTX 980 AMP! Extreme | Crucial Ballistix Tactical 16GB 1866MHz
https://linustechtips.com/topic/408815-help-will-i-kill-my-cpu/#findComment-5506945
Holy shit. That voltage is too high.
Whats the ideal?
https://linustechtips.com/topic/408815-help-will-i-kill-my-cpu/#findComment-5506954
Hello guys
In bios setting is:
NB vcore 1.110
That's just asking to fry your CPU
        Setup
CPU: i3 4160|Motherboard: MSI Z97 PC MATE|RAM: Kingston HyperX Blue 8GB(2x4GB)|GPU: Sapphire Nitro R9 380 4GB|PSU: Seasonic M12II EVO 620W Modular|Storage: 1TB WD Blue|Case: NZXT S340 Black|PCIe devices: TP-Link WDN4800| Montior: ASUS VE247H| Others: PS3/PS4
https://linustechtips.com/topic/408815-help-will-i-kill-my-cpu/#findComment-5506958
Man with 1.3 you do nothing with FX's.
https://linustechtips.com/topic/408815-help-will-i-kill-my-cpu/#findComment-5506960
That is really, really high.
Project Tomahawk:
CPU: Intel Core i7 4790k
Motherboard: Asus Maximus VII Hero
CPU Cooler: Corsair H100i
Memory: 16GB Kingston HyperX Fury 1866 Mhz
GPU: Asus Strix RX 480
PSU: Corsair RM1000
Storage: 2x Western Digital 2TB Enterprise + 240GB Crucial M500 SSD
Case: Corsair Air 540
Additional: Cablemod C-Series black/red kit, SP120, AF140 and AF140 w/ red LED's all around
Project Frankenstein:
CPU: AMD FX 6100
Motherboard: MSI 970 SLI Krait Edition
CPU Cooler: Cooler Master Hyper 212 EVO
Memory: 8GB G.Skill Ripjaws X 1866 Mhz
GPU: MSI R9 280 3G Twin Frozr
Storage: Western Digital 1TB Enterprise + 240GB Partiot Torch SSD
Case: Fractal Design Define S
Sheila (Server):
Dell R210:
CPU: Intel Xeon x3450
Memory: 12GB Crucial ECC 1600 Mhz
Storage: Seagate 3TB Constellation
Marvin (Server)
Dell R210ii
CPU: Intel Xeon E3 1230v2
Memory: 12GB Crucial ECC 1600Mhz
https://linustechtips.com/topic/408815-help-will-i-kill-my-cpu/#findComment-5506962
Well then deal with it, it's your purchase and that's how overclocking works
        Setup
https://linustechtips.com/topic/408815-help-will-i-kill-my-cpu/#findComment-5506982
1.325V max! Electronics are sensitive to higher voltage, especially CPUs. Most electronics don't use more than 5V.
        Setup
https://linustechtips.com/topic/408815-help-will-i-kill-my-cpu/#findComment-5506989
H110
Is your rig in the fridge? I mean these temps don't look right if you are just using a H110...
A h110 can only bring a cpu temp as low as the ambient temp in the room it is in, only exotic stuff can get it lower than ambient.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/408815-help-will-i-kill-my-cpu/#findComment-5506998
 Probably just a bug.
It reports a minimum of 24C higher up.
"It's a taxi, it has a FARE METER."
https://linustechtips.com/topic/408815-help-will-i-kill-my-cpu/#findComment-5507031
My ambient temp is 13-15 celsius. The min temp i think is measuring wrong but the max is right
https://linustechtips.com/topic/408815-help-will-i-kill-my-cpu/#findComment-5507034
Its because AMD CPUs have terrible temp sensors.
https://linustechtips.com/topic/408815-help-will-i-kill-my-cpu/#findComment-5507036
Bruhs... this isn't intel, this crappy SOI could take 1,5 V without problem... Well, the only problem obviously is to dissipate the heat.
Anyway, even at boost clocks it exceeds 1,4 V (1,425 V iirc?)
And yeah this, didn't notice the temps... Use other software, but most probably you're going to have wrong readings (not the first time with AM3+)
This is a signature.
https://linustechtips.com/topic/408815-help-will-i-kill-my-cpu/#findComment-5507040
No, not even close. It is probably around double what it says.
https://linustechtips.com/topic/408815-help-will-i-kill-my-cpu/#findComment-5507041
Om most sites i have been seen the voltage to 6300 to reach 4.5~4.6 is 1.44+
https://linustechtips.com/topic/408815-help-will-i-kill-my-cpu/#findComment-5507043
I think the guy is used to oc intel. What software is better to read the temp?
https://linustechtips.com/topic/408815-help-will-i-kill-my-cpu/#findComment-5507058
That's a bad overclock and forcing your CPU past 1.3V is bad.
        Setup
https://linustechtips.com/topic/408815-help-will-i-kill-my-cpu/#findComment-5507059
Yea true, my amd temps looks like they react very late, but at least they look sort of right :D
https://linustechtips.com/topic/408815-help-will-i-kill-my-cpu/#findComment-5507071
omg
AM3+ dont overclock with 1.3-
https://linustechtips.com/topic/408815-help-will-i-kill-my-cpu/#findComment-5507101
