My friend just got a R9 280x Gigabyte windforce, and has 3 monitors a 1080p, 1600x900, and a 1280x1024 display. When you try to enable all of them, it give the error of "The display settings could not be saved. Please try a different combination of display settings." 2 are on the display ports, and 1 is on the DVI port. Any help?
(I haven't logged in in years, I have to update this)
My PC Spec:
CPU: Intel i7-8700k @ 3.7GHz, Motherboard: , Memory: 16gb , Storage: , Storage: Crucial BX100 250GB, Storage: Seagate Barracuda 3TB 3.5" 7200RPM, Video Card: EVGA GeForce GTX 970 SC(x2), Case: Corsair C70 Green, Power Supply: EVGA SuperNOVA NEX750G GOLD, Operating System: Windows 8.1, CPU Cooler: CORSAIR Hydro Series H100, Optical Drive: LG Internal Super Multi Drive
https://linustechtips.com/topic/405993-problems-with-3-monitors/
miss matched monitors are always a pain to get setup.. even 3 identical monitor sometimes have issues.
my advice.. sell all 3 and get 1 decent monitor.. problem solved.
Gaming PC: • AMD Ryzen 7 3900x • 16gb Corsair Vengeance RGB Pro 3200mhz • Founders Edition 2080ti • 2x Crucial 1tb nvme ssd • NZXT H1• Logitech G915TKL • Logitech G Pro • Asus ROG XG32VQ • SteelSeries Arctis Pro Wireless
Laptop: MacBook Pro M1 512gb
https://linustechtips.com/topic/405993-problems-with-3-monitors/#findComment-5471401
He just AOC i2269VW, the same one I have. I will pass it on. :)
My PC Spec:
https://linustechtips.com/topic/405993-problems-with-3-monitors/#findComment-5471455
Try to change 1 DP monitor to HDMI, might solve the problem.
The gpu supports op to 3 monitors, and there are 4 ports, so 1 port is internally connected to 2 outputs of the gpu, so that explains why you can't save it.
It's stupid, but that's how it is... It's a sort of unwritten rule sadly.
You can try to connect 1 monitor to the iGPU if that's an option.
If you want my attention, quote meh! D: or just stick an @samcool55 in your post :3
Spying on everyone to fight against terrorism is like shooting a mosquito with a cannon
https://linustechtips.com/topic/405993-problems-with-3-monitors/#findComment-5471459
Is the dvi one not working ? Are you doing this with eyefinity or windows? Did you try lowering resolution, unpluging power and repluging?
EVGA SR-2 / 2x Intel Xeon X5675 4.4Ghz OC / 24GB EEC 1800Mhz OC/ AMD RX570 / Enermax Evoliution 1050W / Main RAID 0: 2x256GB 840EVO SSD / BackUp(1) Raid 5: 3x2TB WD HDD / BackUp(2) 8x2TB / Dell U2412M / Dell U2312HM
https://linustechtips.com/topic/405993-problems-with-3-monitors/#findComment-5471471
I will send him a link to a HDMI to DVI cable.
Any 2 work together, all 3 though do not.
My PC Spec:
https://linustechtips.com/topic/405993-problems-with-3-monitors/#findComment-5471497
Did you try to take out the power plug and replug it while configuring? Set the monitors to lower res?
https://linustechtips.com/topic/405993-problems-with-3-monitors/#findComment-5471533
I use nvidia so im not familiar with amds wording but are you running into problems trying to get it working in surround?  or just power all 3 to get an image on them
System Specs
CPU: Ryzen 5 5600x | Mobo: Gigabyte B550i Aorus Pro AX | RAM: Hyper X Fury 3600 64gb | GPU: Nvidia FE 4090 | Storage: WD Blk SN750 NVMe - 1tb, Samsung 860 Evo - 1tb, WD Blk - 6tb/5tb, WD Red - 10tb | PSU:Corsair ax860 | Cooling: AMD Wraith Stealth  Displays: 55" Samsung 4k Q80R, 24" BenQ XL2420TE/XL2411Z & Asus VG248QE | Kb: K70 RGB Blue | Mouse: Logitech G903 | Case: Fractal Torrent RGB | Extra: HTC Vive, Fanatec CSR/Shifters/CSR Elite Pedals w/ Rennsport stand, Thustmaster Warthog HOTAS, Track IR5,, ARCTIC Z3 Pro Triple Monitor Arm | OS: Win 10 Pro 64 bit
https://linustechtips.com/topic/405993-problems-with-3-monitors/#findComment-5471554
Just an image
My PC Spec:
https://linustechtips.com/topic/405993-problems-with-3-monitors/#findComment-5471936
