Noctua
LTT's Fastest single core CineBench 11.5/15 score on air with i7-4790K on air
Main Rig
CPU: i7-4770K @ 4.3GHz 1.18v, Cooler: Noctua NH-U14S, Motherboard: Asus Sabertooth Mark 2, RAM: 16 GB G.Skill Sniper Series @ 1866MHz, GPU: EVGA 980Ti Classified @ 1507/1977MHz , Storage: 500GB 850 EVO, WD Cavier Black/Blue 1TB+1TB,  Power Supply: Corsair HX 750W, Case: Fractal Design r4 Black Pearl w/ Window, OS: Windows 10 Home 64bit
Plex Server WIP
CPU: i5-3570K, Cooler: Stock, Motherboard: ASrock, Ram: 16GB, GPU: Intel igpu, Storage: 120GB Kingston SSD, 6TB WD Red, Powersupply: Corsair TX 750W, Case: Corsair Carbide Spec-01 OS: Windows 10
Lenovo Legion Laptop
CPU: i7-7700HQ, RAM: 8GB, GPU: 1050Ti 4GB, Storage: 500GB Crucial MX500, OS: Windows 10
Well you could go with a custom watercooling loop, but I can wholeheartedly recommend the Dark Rock Pro 3.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
It would help to mention the rest of your specs as well as where you're shopping/located, and budget.
Have you tried lowering the fan speed?
Apparently you can try the dark rock pro 3 but remove the fans so it's literally completely silent, and it would still work well under load. (linus did this) and since you won't be overclocking, i think that would work as a silent solution, but obviously, $$$. If you want something cheap, ehhh i don't have too many recommendations, but maybe a 212 evo? I don't know. the stock intel heatsink is actually pretty quiet if you ask me, even at full speed, it's not too badly loud and you won't be need full speed unless you are running benchmarks on that 4460 anyway.
BRRRT!
PC
  • ASUS TUF GAMING B550M Plus
  • Ryzen 5 5600X undervolted
  • Gigabyte VISION OC RTX 3070 undervolted
  • 32GB Teamgroup Dark Alpha 3600 MHz CL18
  • Corsair TX750M
  • Fractal Design Meshify C Mini
Sim Equipment
  • Logitech Extreme 3D Pro & Thrustmaster TWCS Throttle
  • Logitech G27 with pedals and H-shifter
  • TrackIR 4
If you can, I recommend the Thermalright! Good looks, and doesn't cost too much. If your case fans are good enough, this is similar to their fully passive heatsink, so you should be able to run it dully passive. since I don't own one, it's hard to say exact performance, but in in this article about temps and noise, it is similar or better to the D15, and is consistently topping the charts.
I like good humans and good food
As a Dark Rock owner, I can personally attest to this. It's already so quiet though, you'd probably have many louder things in your system that you need to address before running the dark rock on passive.
