so when i start a work in minecraft it takes forever to load then it looks like this http://imgur.com/QWzTtmn and when i press save and quit minecraft stops responding and i have to force close it does anyone know how to fix this? i have never ran it on my pc before this is the first time
EDIT: i fixed the link and i dont have mods
https://linustechtips.com/topic/405236-problem-with-minecraft/
Do you have any mods installed. What are your specs?
so when i start a work in minecraft it takes forever to load then it looks like this http://imgur.com/E3gXzCK and when i press save and quit minecraft stops responding and i have to force close it does anyone know how to fix this? i have never ran it on my pc before this is the first time
https://linustechtips.com/topic/405236-problem-with-minecraft/#findComment-5461870
What exactly happens?
I see a picture of your browser..
But just try reinstalling Minecraft and Java (get 64 bit Java)
https://linustechtips.com/topic/405236-problem-with-minecraft/#findComment-5461879
wow i didn't check the pic it didn't capture minecraft but the tabs behind it -_- and i have 64 bit java i needed it for my twitch bot and the world is just black i can see the sky and the void nothing loads and i dont fall but i cant walk
https://linustechtips.com/topic/405236-problem-with-minecraft/#findComment-5461894
i have HUGE problems as well i would suggest changing one thing as a time like removing texture packs and then change your java as i have an issue where i cannot support some java without it auto shutting down
<p>Wish I could have this already!! : http://pcpartpicker.com/p/qTLRjX
https://linustechtips.com/topic/405236-problem-with-minecraft/#findComment-5461908
i have no mods  the world is just black i can see the sky and the void nothing loads and i dont fall but i cant walk and my specs are x4760k 4gb of g.skill ram and R7 260 GPU
also you may need more ram depending on your settings
https://linustechtips.com/topic/405236-problem-with-minecraft/#findComment-5461910
Have you tried making a new world?
Minecraft with low RAM only cause stuttering.
I was able to play Minecraft with 4GB before (and I can only assume they have improved optimization)
https://linustechtips.com/topic/405236-problem-with-minecraft/#findComment-5461922
4gb of ram is completely fine for mc i played it on my laptop a few days ago with 4gb of ram and it ran perfectly at the same redner distance i ran at on my PC and i tired lower render didnt work and max render and didnt work
https://linustechtips.com/topic/405236-problem-with-minecraft/#findComment-5461935
