Problem with netowrk.
Go to solution Solved by Altecice,
Soo its a DNS error. I wonder if its your ISP's DNS thats poop. Why dont you try changing DNS from automatically allocated to 8.8.8.8 (Googles DNS).
From time to time whenever I try to any enter web I get this error
Sometimes one restart is enough, other times I have to restart web few times until it starts loading.
It gets frustrating when this happens few times a day every day.
I have two systems connected via same router, both of them have this problem.
Any idea why is it happening?
Laptop: Acer V3-772G  CPU: i5 4200M GPU: GT 750M SSD: Crucial MX100 256GB
DesktopCPU: R7 1700x GPU: RTX 2080 SSDSamsung 860 Evo 1TB
https://linustechtips.com/topic/405221-problem-with-netowrk/
Happens to me as well, think it's because my router is crap and there a lot of interference in my house because it doesn't happen at all over a wired connection.
CPU: 6600K @ 4.6Ghz | COOLER: H100i GTX | MOBO: Asus Z170 AR | GPU: EVGA GTX 1080 Ti Hybrid | RAM: G.Skill Trident Z RGB 16GB |
CASE: Corsair 760T | PSU: Corsair RM750x | STORAGE: Samsung 850 EVO 250GB & Seagate 2TB | KEYBOARD: K70 RGB | MOUSE: Deathadder Elite
https://linustechtips.com/topic/405221-problem-with-netowrk/#findComment-5461662
Your internet speed probably isnt fast enough. I have 120MBPs down and never get that error. Probably the only thing you can do is get an higher internet speed. Or maybe your router isnt fast enough.
Im not a specialist or anything like that but these are my guesses
System: CPU - I5-6500 Motherboard - Asus B150M-A RAM - Crucial ballistix sport 2x4GB DDR4 @2400MHz GPU - RX 480 PSU - Seasonic S12II 520W Case - Aerocool Aero-800 HDD - Seagate 1TB SSD - PNY CS1311 120GB Monitor - AOC G2260VWQ6
https://linustechtips.com/topic/405221-problem-with-netowrk/#findComment-5461669
dont make me jellyous :(
https://linustechtips.com/topic/405221-problem-with-netowrk/#findComment-5461695
Here in the netherlands most people have that speed. For most providers 100MBPs is the slowest you can order xD For fiber that is
https://linustechtips.com/topic/405221-problem-with-netowrk/#findComment-5461705
Here in the netherlands everyone has that speed. For most providers 100MBPs is the slowest you can order xD For fiber that is
 4497994585.png The best speed possible in my area.  :angry:
https://linustechtips.com/topic/405221-problem-with-netowrk/#findComment-5461728
Worth a shot.
https://linustechtips.com/topic/405221-problem-with-netowrk/#findComment-5461739
It is definitely an issue related to domain name resolution so changing the DNS server is going to your first step in troubleshooting. I never use my ISPs provided DNS servers anymore. For one they are seemingly down for a minimum of 5 hours per week and secondly they alter domain name queries if they feel you were looking for something else. Yeah it may be nice if you accidently mistype a URL but I'd rather not have my ISP poisoning my DNS results.
https://linustechtips.com/topic/405221-problem-with-netowrk/#findComment-5461828
i have 6mb down at&t dsl I get ALOT and I mean ALOOOOOOOOOOOOOOOOT of thoes errors every day :(
Guys, looks like @Altecice method works. Give it a shot. Need more testing tho.
https://linustechtips.com/topic/405221-problem-with-netowrk/#findComment-5462271
-snip-
Check your DNS, change the IPs to Google's DNS (8.8.8.8, 8.8.4.4). Maybe it's a routing issue, or your line is bad and you have a lot of packet drops...
I have a backup business line, 15/15Mbps. I bet my ass that I can load any site 3x faster than you.
https://linustechtips.com/topic/405221-problem-with-netowrk/#findComment-5463461
Just saying, speeds are measured in bits not bytes.
I know, I have 120 megabit per second, which is roughly 15 megabyte per second when downloading things
https://linustechtips.com/topic/405221-problem-with-netowrk/#findComment-5467622
He was just commenting because you said "100 MBPs", which would mean 100 Megabytes per second. Remember, Bytes = Big B, Bits = little b.
Might seem trivial to type out that difference, but you're in the Networking subforum. Details matter here.
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
https://linustechtips.com/topic/405221-problem-with-netowrk/#findComment-5473860
Looks like problem solved. Not a single error so far.
DNS can be a bitch sometimes, and ISP's are notorious for having shitty DNS servers. Fortunately my ISP does pretty well in that regard, but if I ever have problems, I always fall back to Google DNS.
https://linustechtips.com/topic/405221-problem-with-netowrk/#findComment-5476565
