Smallest possible PSU to power ONLY a GPU.
Claryn
Hi.
I am going to run an eGPU setup where I have a 960 running over Thunderbolt to my mac. I need some sort of power supply that can give the card enough power. I don't want to go about buying a large ATX power supply jus to have a single 6pin.
Are there any power supplies that can do this? I have been looking at the HD Plex but I am unsure if it will work.
Thanks
Running Arch with i3-gaps on a Thinkpad X1 Extreme
Data Science Postgrad
solder it to a car battery
CPU: Intel i7 5820K @ 4.20 GHz | MotherboardMSI X99S SLI PLUS | RAM: Corsair LPX 16GB DDR4 @ 2666MHz | GPU: Sapphire R9 Fury (x2 CrossFire)
Storage: Samsung 950Pro 512GB // OCZ Vector150 240GB // Seagate 1TB | PSU: Seasonic 1050 Snow Silent | Case: NZXT H440 | Cooling: Nepton 240M
FireStrike // Extreme // Ultra // 8K // 16K
I would say a CX430M.
Main rig on profile
VAULT - File Server
Intel Core i5 11400 w/ Shadow Rock LP, 2x16GB SP GAMING 3200MHz CL16, ASUS PRIME Z590-A, 2x LSI 9211-8i, Fractal Define 7, 256GB Team MP33, 3x 6TB WD Red Pro (general storage), 3x 1TB Seagate Barracuda (dumping ground), 3x 8TB WD White-Label (Plex) (all 3 arrays in their respective Windows Parity storage spaces), Corsair RM750x, Windows 11 Education
Sleeper HP Pavilion A6137C
Intel Core i7 6700K @ 4.4GHz, 4x8GB G.SKILL Ares 1800MHz CL10, ASUS Z170M-E D3, 128GB Team MP33, 1TB Seagate Barracuda, 320GB Samsung Spinpoint (for video capture), MSI GTX 970 100ME, EVGA 650G1, Windows 10 Pro
Mac Mini (Late 2020)
Consoles: Softmodded 1.4 Xbox w/ 500GB HDD, Xbox 360 Elite 120GB Falcon, XB1X w/2TB MX500, Xbox Series X, PS1 1001, PS2 Slim 70000 w/ FreeMcBoot, PS4 Pro 7015B 1TB (retired), PS5 Digital, Nintendo Switch OLED, Nintendo Wii RVL-001 (black)
You could just get this and paperclip it...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139026
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817256109&cm_re=sx_600_g-_-17-256-109-_-Product
You should check out Silverstone's SX600-G. It's an sfx size psu which is currently the smallest they make, it's fully modular so you wouldn't have any extra cables hanging off of it, and it's 600w which would give you plenty of headroom should you decide to upgrade in the future.  It has an 80+ Gold rating and semi fanless technology, although there have been reports of fan noise (ticking and squeaking) by a lot of people, it seems to me that there are just as many people reporting they have no fan noise so it might be a gamble.  With all that said, I still think it would be a good psu but that is ultimately your decision.  I just thought you might be interested in it seeing as how it's modular and all.  Hope this helps!
Also consider an external PSU. I am using the Dell DA-2 220W with my external GTX970 ;)
