Help with PC upgrade
Go to solution Solved by LlamaDelRey,
okay thanks all for the help!
I ended up buying a "upgrade package"
FX-6300
ASUS R9270X-DC2-2GD5 2GB GDDR5 DVI-I DVI-D HDMI DisplayPort
ASUS M5A97 LE R2.0 SocketAM3+ 4xDDR3 32GB ATX AMD 970
KINGSTON 8GB 1600MHz DDR3 CL10 DIMM HyperX Fury Black Series
Problem solved, close thread =)
Hello!
I'm thinking about upgrading my graphics card only right now but becasue I'm so bad at this I decided to join this forum!
Right now I have:
AMD Athlon II X4 620 Processor (4 CPUs), ~2.6GHz
6gig of ram
NVIDIA Geforce GT 240
motherboard pegatron mzn7b
Is it even possible to get a decent upgrade if I change my graphics card only and if so to which one?
Thanks!
https://linustechtips.com/topic/403579-help-with-pc-upgrade/
if you can get an r7 265 or a gtx 750ti (otherwise you could wait for the upcming gtx 950ti)
AMD Ryzen R7 1700 (3.8ghz) w/ NH-D14, EVGA RTX 2080 XC (stock), 4*4GB DDR4 3000MT/s RAM, Gigabyte AB350-Gaming-3 MB, CX750M PSU, 1.5TB SDD + 7TB HDD, Phanteks enthoo pro case
https://linustechtips.com/topic/403579-help-with-pc-upgrade/#findComment-5441602
I dont really have a budget but less than 400€
Why GPU only?
You can get a GTX 970 for under 400, but would it be worth it with a bottlenecking CPU?
https://linustechtips.com/topic/403579-help-with-pc-upgrade/#findComment-5441625
or can get a 4460 and a z97 and a r9 280 or 270
Yes.
https://linustechtips.com/topic/403579-help-with-pc-upgrade/#findComment-5441634
FX-6300
https://linustechtips.com/topic/403579-help-with-pc-upgrade/#findComment-5442350
