after about 15 minutes of constant playing at 70-100 fps on normal settings i start to get lag spikes. Usually happens when i crash hard, or drive fast. I have all the latest drivers, not sure what the issue is? I don't think its my graphics card, but i could be wrong. What do you think?
Specs:
NVIDIA GTX 770 2GB (EVGA)
Intel Core i5 4440 @ 3.1GHz
Kingston Hyper-X DDR3 1600MHz
https://linustechtips.com/topic/403467-gta-v-lag-help/
Playing on an HDD i assume ?
Turned off extended shadow scaling and draw distance and high res shadows ?
AMD 5000 Series Ryzen 7 5800X| MSI MAG X570 Tomahawk WiFi | G.SKILL Trident Z RGB 32GB (2 * 16GB) DDR4 3200MHz CL16-18-18-38 | Asus GeForce GTX 3080Ti STRIX | SAMSUNG 980 PRO 500GB PCIe NVMe Gen4 SSD M.2 + Samsung 970 EVO Plus 1TB PCIe NVMe M.2 (2280) Gen3 | Cooler Master V850 Gold V2 Modular | Corsair iCUE H115i RGB Pro XT | Cooler Master Box MB511 | ASUS TUF Gaming VG259Q Gaming Monitor 144Hz, 1ms, IPS, G-Sync | Logitech G 304 Lightspeed | Logitech G213 Gaming Keyboard |
PCPartPicker
https://linustechtips.com/topic/403467-gta-v-lag-help/#findComment-5440207
Sounds like either your CPU or GPU is overheating, causing it to underclock to keep cool. Use a temperature monitoring software like SpeedFan to make sure your parts aren't overheating.
Another possibility is that your VRAM is maxed out and the game is stuttering because it is pulling from system memory.
https://linustechtips.com/topic/403467-gta-v-lag-help/#findComment-5440227
Specs:
There's actually a patch issue
http://linustechtips.com/main/topic/403285-rockstar-acknowledges-performance-issues-in-gta-v-pcs-latest-128-patch/
According to this the 1.28 patch caused performance to drop by a considerable amount
https://linustechtips.com/topic/403467-gta-v-lag-help/#findComment-5440249
How do i check the vram thing? That could be it Not the tempatures though. They are pretty cool.
https://linustechtips.com/topic/403467-gta-v-lag-help/#findComment-5440254
it's all blank quotes
PCPartPicker
https://linustechtips.com/topic/403467-gta-v-lag-help/#findComment-5440307
