i recently got a surface pro 3 and it has been my main gaming computer.. ever since then ive been wanting to build an actual pc though. (arkham knight...)i made a list on pcpartpicker and heres what i got.. looking to run high or ultra in most gamesat 1080p.. ( i havent chosen a case or a monitor)
http://pcpartpicker.com/p/WnC4Vn
https://linustechtips.com/topic/401901-about-to-start-a-build/
Get a 250GB ssd and upgrade your motherboard so its compatible with the 4690k
Join da discord
(Intel Core i5 4590 - XFX R9 280 - ASUS z97-A USB 3.1 - EVGA SuperNOVA 750B - 16GB EVGA DDR3-EDITION - NZXT H440 -
WD BLACK 1TB - OZC ARC 100 240gb)
#locked(ง ͠° ͟ل͜ ͡°)ง
https://linustechtips.com/topic/401901-about-to-start-a-build/#findComment-5418709
what are you talking about, its compatible
I think he's talking about the bios update it needs, look at the bottom of the page.
Happy to help with any tech problems. Windows 10 installing guide here.
----i5 4570s----gigabyte z97x-sli----8gb ddr3----gigabyte g1 gaming 960----HAF 912----120gb ssd----1tb hdd----500w evga----
https://linustechtips.com/topic/401901-about-to-start-a-build/#findComment-5418724
I'll make ya one, brb
https://linustechtips.com/topic/401901-about-to-start-a-build/#findComment-5418761
just because you need a bios update dosen't mean its incompatiable lol
I know. Im having the same problems with my PC. my memory does not run at the right speeds and i cant overclock.
Join da discord
https://linustechtips.com/topic/401901-about-to-start-a-build/#findComment-5418763
op your mobo is fine
https://linustechtips.com/topic/401901-about-to-start-a-build/#findComment-5418765
Saved ya money. No point in getting the 4690k if you can't overclock on the board
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($166.95 @ SuperBiiz)
Motherboard: MSI B85-G41 PC Mate ATX LGA1150 Motherboard  ($79.98 @ OutletPC)
Memory: Kingston 8GB (2 x 4GB) DDR3-1600 Memory  ($46.99 @ Newegg)
Video Card: Club 3D Radeon R9 280X 3GB royalQueen Video Card  ($214.99 @ NCIX US)
Case: Fractal Design Core 2500 ATX Mid Tower Case  ($46.99 @ Directron)
Optical Drive: LG GH24NSC0B DVD/CD Writer  ($12.99 @ Newegg)
Wireless Network Adapter: TP-Link TL-WDN4800 802.11a/b/g/n PCI-Express x1 Wi-Fi Adapter  ($37.24 @ Amazon)
Total: $796.61
Generated by PCPartPicker 2015-07-06 20:34 EDT-0400
https://linustechtips.com/topic/401901-about-to-start-a-build/#findComment-5418785
the whole point of this build was to get a start.. this is not the final product.. i will probably get a z97 in case i ever do decide to overclock.. plus i was looking for a rough estimate.. the only thing i would look at upgrading is the video card.. that i would probably bump to a 970.. be mindful that im on a 1200$ budget
https://linustechtips.com/topic/401901-about-to-start-a-build/#findComment-5422278
