I just wanted to show you techies a frame quarry i made in Minecraft! ;)
What it does it punches from level 70 to 0 every 7 seconds in a radius od 16x1, and stores the mined stuff digitally on a server, and not in chests. Then, later you can take the hard drives out of the server and transfer them to your base and you have your stuff that is mined.
How does it work? Let me explain.
The whole machine is build using frames. When frames touch some object, it sticks to them. Then you can move the frames.
The block with the arrow is called a frame pusher. The first one pushes the whole structure forward, every 7 seconds, and it stays in place as the structure moves. The second pusher has a constant on signal from the redstone block, and it pushes the first one back in place.
The black thing is called a Tessaract. It transfers power wirelessly, and its crazy expensive to make in survival. The two blocks with the stripes on them are the server controllers. They take the mined stuff and store them on server drives.
The white blocks punch a hole on the ground in around 7 seconds, and its called a Mining Well. The gray blocks are server interfaces. They transfer the items from the Mining Well into the server controller, which then stores it on HDDs.
This times the machine. The first block is a timer, which pulses every 7 seconds. The block in the middle is a pulse extension block, repeater, and it extends that pulse 4 minecraft ticks. The last one is a wireless router used to signal the frame pusher...
All power wires are hidden inside the frame, using Microblocks.
The white thing is called a server terminal interface. I can use it to browse the hard drives...
Which can store a SHITLOAD of stuff on them. There is a process of ore doubling, and for every ore i get 2 ingots. Now calculate how much stuff i got!
This was 10 minutes of mining.
Some more screenshots of the terrain destruction this thing does!
And another shot of the whole machine. Man i am proud! :P
See ya guys l8r! What do you thing of my mad quarry? :D
Primary: Lenovo T61 / Intel Core2Duo T7200 @ 2.2GHz / 3GB DDR2 / NVIDIA Quadro NVS 140M / Fedora 22 <<<< THE WHITE KNIGHT
Secondary: Compaq Presario CQ56 / AMD V130 @ 2.3GHz / 2GB DDR3 / AMD Radeon HD 4250 / Windows 8.1 <<< THE FORGOTTEN HERO
https://linustechtips.com/topic/400894-minecraft-minig-quarry-showcase/
NOICE.
I want that map tho.
Main rig on profile
VAULT - File Server
Sleeper HP Pavilion A6137C
OptiPlex 7040M
Mac Mini (Late 2020)
I made a quarry in vanilla once. And by that I mean I dug out a huge hole in vanilla.
Was pretty cool I like to think.
As you can see around the 10 minute mark, a huge hole was begun. I probably spent 50 or so hours on that project alone. Was it worth it? No. Was it different? Yes.
I had a really high voice for a 16 year old. Damn. It's changed quite a bit in the last year.
Now I want to get back into paying Minecraft. Have played it two or three times since January / February if I remember correctly
(Not trying to self advertise my channel, just trying to show off my creation)
CPU: R5 5800X3D Motherboard - MSI X570 Gaming Plus RAM - 32GB Corsair DDR4 GPU - XFX 7900 XTX 4GB Case - NZXT H5 Flow (White) Storage - 2X 4TB Samsung 990 Pro PSU - Corsair RM100E Cooling - Corsair H100i Elite Capellix Keyboard Corsair K70 (Brown Switches)  Mouse - Corsair Nightsword RGB
As you can see around the 10 minute mark. I had a really high voice for a 16 year old. Damn. It's changed quite a bit in the last year.
I cant concentrate on the gameplay because of the song...oh god why Tristam? Im such a fanboy *_*
I had a bit of a Tristam phase last year. Still listen to some of his stuff. Not as much now as I did then.
Problem is he doesn'n make anything good these days :/
NOICE.
Im not sure if it would load on vanilla minecraft xD
People still play this shite?
Intel i7 7700K | MSI Z270 Gaming M3 | MSI GTX 1070 Gaming X| Corsair Vengeance LPX 2x8GB DDR4 3000Mhz Samsung EVO 850 250GB | WD Blue 1TB | Corsair CS650M | Thermalright Macho Rev. A | NZXT S340
CM Storm Quickfire TK [MX Blues] | Zowie FK1 |  Kingston HyperX Cloud
Very true. I haven't been listening to much electronic music in the last few months. Been sticking to metal and pop punk.
Awwww...
Well, you know, it's not shit, so...
Main rig on profile
VAULT - File Server
OptiPlex 7040M
I wish I could still enjoy Minecraft :(
Awwww...
wooooo bae burn <3
"Unofficially Official" Leading Scientific Research and Development Officer of the Official Star Citizen LTT Conglomerate | Reaper Squad, Idris Captain | 1x Aurora LN
Game developer, AI researcher, Developing the UOLTT mobile apps
G SIX [My Mac Pro G5 CaseMod Thread]
