so i am trying to make this laptop faster for a friend he told me that it is around 2008. my question is will a SSD still make a difference as i presume its SATA 2 due to the age
i understand the reed and write speeds wont be as advertised how ever will the quick boot and snappiness of an ssd be there
My Personal PC 'Apex' https://uk.pcpartpicker.com/user/LiamBetts123/saved/3rTNnQ
Intel Core i9 9900k, ASUS Z390-A, RTX 2080TI, Meshify C, HX 850i, 32GB Gskill Trident Z RGB @ 3200MHZ, 500GB NVME, 500GB SSD & 2 x 4TB Baracudas
1
https://linustechtips.com/topic/399801-how-much-difference-will-a-ssd-make/
Because most operations taking place in an OS are 4K and 4K32, you will see a significant performance increase, even if the laptop is not SATAIII compliant. FYI, I've tested 4K and 4K32 between both my hard drives and Intel 520 SSD - the SSD is something like 100x faster during those operations.
SATA 2 has a max theoretical speed of 375 MB/s (3 Gb/s), so let's say the SSD will get ~300 MB/s, that's still quite a bit faster than a traditional hard drive, which I believe top out at around 150 MB/s - 200 MB/s
Intel Core i7-5820K (4.4 GHz) | Gigabyte GTX 970 G1 Gaming | Corsair Vengeance LPX 16GB  | 2x 360mm Custom Loop (Noctua iPPC) | ASRock X99 Extreme6 | Samsung 840 EVO 250GB | Fractal Design Define S | Corsair HX750 | Windows 10 | Corsair M65 RGB PRO | Corsair K70 RGB LUX (CherryMX Brown) | Beyerdynamic Custom One Pro & Creative Sound Blaster Z | Nexus 6P (32GB Aluminium) | Check out my setup: Project Kalte Here!
It'll make the laptop feel like new, given that the CPU nor RAM arent holding back the system
My arsenal: i7-9700k Gaming Rig, an iPhone, and Stupidity.
it has 3gb ram and AMD TURLON X2 @ 3.00 GHZ
1
