As an owner of the maximus Hero IV I have only used the SupremeFX audio chip as my audio device. To what extent would it be worthwhile to get a dedicated sound card? Furthermore at what price range will it be effective to buy a dedicated audio solution over the supremeFX chip?
Currently I use Corsair SP2500 soundsystem and turtlebeach X12 headphones (sometimes Jaybird Bluebud Xs).
https://linustechtips.com/topic/399709-supremefx-audio-chip-alternatives/
You won't benefit much by buying a dedicated soundcard, the high end Asus boards are equipped with really good audio. Want better audio quality? Buy studio headphones from a well known brand.
Asus B85M-G / Intel i5-4670 / Sapphire 290X Tri-X / 16GB RAM (Corsair Value 1x8GB + Crucial 2x4GB) @1333MHz / Coolermaster B600 (600W) / Be Quiet! Silent Base 800 / Adata SP900 128GB SSD & WD Green 2TB & SG Barracuda 1TB / Dell AT-101W / Logitech G502 / Acer G226HQL & X-Star DP2710LED
Sound card:no benefit at all. External solution: maybe a little benefit, but not worth it if there aren't glaring problems with your current setup.
Hey! New SIgnature!
I'm supposedly a person on the Internet, but you'll never know if I'm human or not ;)
