no
OS?
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/398587-need-help-for-a-friend/#findComment-5372851
location?
for LoL it won't take much to run it at 60 fps. an athlon 860k and a gtx 750ti should do the trick.
My rig:
CPU: i5 4690k 24/7 @4.4ghz (1.165v) Max 4.7ghz (1.325v) COOLER: NZXT Kraken X61 MOBO: Asus Z97-A   RAM: 16GB Crucial Ballistix Tactical   GPU: EVGA GTX 970 SSC   PSU: EVGA GS 650W   CASE: NZXT Phantom 530 HDD: WD Caviar Blue 1TB + WD Black 2TB
https://linustechtips.com/topic/398587-need-help-for-a-friend/#findComment-5372855
http://pcpartpicker.com/p/j2W3GX That's pretty much the best you'll get for 550$ while still using all around quality components. I don't condone piracy so something like SteamOS should work just fine for the OS as it's uber easy to install until you can get a real fully featured OS.
Sergeant, United States Marine Corps
Network Administrator, Comptia A+, Security+, Cisco Certified Networking Associate
From a G3258 to dual Xeon E5-2670's
https://linustechtips.com/topic/398587-need-help-for-a-friend/#findComment-5372862
I like this build, it'd be hard to get any better for the price.
For the Best builds and Price lists here is a world where many points of the price have been predefined already for your convenience!
The Xeon E3 1231 V3 IS BETTER Than the Core i5 4690K and a Significantly better value for the non-overclockers or value shoppers.
The OS is like a kind food, Try it before saying if you like it or don't.
https://linustechtips.com/topic/398587-need-help-for-a-friend/#findComment-5372909
sorry but all these other pc part pickers are using NEW parts....
try this out for size, i know for a FACT it can run BF4 at near max settings at 1080p 60fps EASY. i was getting about 80fps.
http://pcpartpicker.com/p/ZkW3GX
lolllllll don't listen to that troll
https://linustechtips.com/topic/398587-need-help-for-a-friend/#findComment-5372921
Thanks, I and the other build posted by Blueballs has an i5 but that's not really needed as in nearly every situation the i3 and the i5 are pretty much identical. There won't be a real performance increase and it's gonna be 80$ over budget.
https://linustechtips.com/topic/398587-need-help-for-a-friend/#findComment-5372924
a g3258 will smash an i3 even with a small overclock... and you dont need a 960... a 750ti is PLENTY for LoL and even games like dying light. 1080p isnt hard to drive.
A G3258 is a nice CPU but it's not good for really any mutli-media activities or streaming. Also the 960 would be super useful especially if you want to use DSR to make low intensity game look far better. You'll also be able to run the more demanding games out there if you need to.
https://linustechtips.com/topic/398587-need-help-for-a-friend/#findComment-5372940
im not a troll... i have this EXACT pc... just a different case and psu... sorry but for simple gaming you dont need a 120 cpu and 200 gpu... put that money somewhere else like a 120gb ssd or something
SSD's aren't that necessary and the G3258 suffers for pretty much anything that isn't gaming / web browsing.
https://linustechtips.com/topic/398587-need-help-for-a-friend/#findComment-5372946
A G3258 will perform slightly slower AT BEST, it suffers from games that don't support dual cores, and more frequent frame rate drops than the i3.
See various i3 vs G3258 videos for proof.
Go for the GTX 960, It is awesome! sometimes it is almost twice as fast as the 750 Ti who can get 45FPS on MAX for BF4...  Not to mention SLI and a sweet TDP.
https://linustechtips.com/topic/398587-need-help-for-a-friend/#findComment-5372952
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor  ($166.95 @ SuperBiiz)
Motherboard: MSI H81M-P33 Micro ATX LGA1150 Motherboard  ($41.98 @ Newegg)
Memory: PNY XLR8 8GB (1 x 8GB) DDR3-1600 Memory  ($43.99 @ Newegg)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($52.49 @ OutletPC)
Video Card: Sapphire Radeon R9 280X 3GB Video Card  ($227.98 @ Newegg)
Case: Fractal Design Core 1000 USB 3.0 MicroATX Mid Tower Case  ($34.99 @ Directron)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($54.99 @ NCIX US)
Total: $623.37
A little over but you can get a lower end 280x for $40 less.
The 280x gives a pretty large improvement over the GTX 960.
https://linustechtips.com/topic/398587-need-help-for-a-friend/#findComment-5372964
well from PERSONAL exp... a g3258 OC at 4.0ghz on a stock cooler with a non OC 750ti can play dying light at 1080p MAX settings at about 50fps....
i was running dual 1080p screens and could video edit, 3d design and anything JUST FINE.... unless your making a job out of it, a few extra secs of rendering time in order to save alot of money is more then worth it.
https://linustechtips.com/topic/398587-need-help-for-a-friend/#findComment-5372966
Troll. STOP SPREADING INCORRECT INFORMATION.
BF 4 maxed out will play at like 20fps with a 750ti
LMAO 8x msaa on a 750ti....
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
https://linustechtips.com/topic/398587-need-help-for-a-friend/#findComment-5372971
here you go:
http://pcpartpicker.com/p/L4YgjX
happy building
#1builder2k16
This +1
https://linustechtips.com/topic/398587-need-help-for-a-friend/#findComment-5372981
