Emergency Car Help?
I was driving today when my red check engine light came on. Got home zero coolant (If you know me you'd know how much a problem this is). I have replaced the Rad, Pump and a couple of hoses. So my coolant is diapering, not leaking on the ground. I put coolant in it. I drove 3 miles. Then merged on the freeway to come home. I was trying to get infront of a truck and floored it.. it just slowley jolted forward not what the 5.0L normal's does. It pulls pretty hard normally. What might the problem be?
@AlwaysFSX @terrytek @techswede
https://linustechtips.com/topic/394837-emergency-car-help/
What car do you have?
Main Gaming PC (new): HP Omen 30L || i9 10850K || RTX 3070 || 512GB WD Blue NVME || 2TB HDD, 4TB HDD, 8TB HDD ||  750W P2 ||  16GB HyperX Black DDR4
Main Gaming PC (old, still own) : Intel Core i7 7700K @5.0Ghz || GPU: GTX 1080 Seahawk EK X || Motherboard: Maximus VIII Impact || Case: Fractal Design Define Nano S || RAM : 32GB Corsair Vengeance LPX
Cooling: EK XRES D5 100mm || Alphacool ST30 280mm w/ Vardars || Alphacool ST30 240mm w/ Vardars || Swiftech 3/8 x 1/2'' Lok-Seal Compressions || Swiftech EVGA Hydrocopper Block || Primochill Advanced LRT Orange || Distilled Water
Folding@Home Rig: 2x X5690s @4.6Ghz || GPUs: 2x Radeon HD 7990 || Motherboard: EVGA SR-2 || Case: Corsair 900D || RAM: 48GB Corsair Dominator GT 2000Mhz CL9
Ethereum Mining Rig: Pentium G4400 || Gigabyte Z170X-UD5 TH || 2x GTX 1060s (Samsung & Hynix) 1x GTX 1070 (Micron), 2x RX480s BIOS modded (Samsung), 1x R9 290X 8GB, 1x GTX 1660 Super = ~ 195 Mh/s
Peripherals: 3x U2412M (5760x1200), 1x U3011 (2560x1600) || Logitech G710 (Cherry Blues) || Logitech G600 || Brainwavz HM5 with @Gofspar Mod
Laptop: Dell XPS 15 || "Infinity Edge" 4K IPS Screen || i7 7700HQ || GTX 1050 || 16GB 2400Mhz RAM
https://linustechtips.com/topic/394837-emergency-car-help/#findComment-5327547
You might have a coolant leak in to the cylinders.. Which would be very bad. I'd top it up and go through and examine every piece of tubing for the coolant, go look at the radiator, and go run an emissions test to see if you're leaking coolant in to a cylinder. Maybe check the oil too to see if it's going in to that somehow.
https://linustechtips.com/topic/394837-emergency-car-help/#findComment-5327550
Check all hoses, and the radiator. Nothing in regards to leaks. Would a compression test help?
https://linustechtips.com/topic/394837-emergency-car-help/#findComment-5327556
I forgot to mention it is going back and forth from hot to cold rapidly.
*I know this isn't helpful but I don't know enough about car mechanics to help you. Sorry son.*
https://linustechtips.com/topic/394837-emergency-car-help/#findComment-5327586
Yeah I think you might be boiling the coolant off.. Your radiator cap is on snugly, right? Maybe the thermometer is loose and coolant is disappearing from there?  :unsure:
https://linustechtips.com/topic/394837-emergency-car-help/#findComment-5327593
As long as I have coolant it stays well cool. Only if I get low does it move rapidly. The cap is very tight.
https://linustechtips.com/topic/394837-emergency-car-help/#findComment-5327608
I do not smell coolant while I am driving. I am thinking it is leaking into the block..
Could be a gasket leak. Are you able to take it to someone to check the coolant for any contaminants that could come from various parts of the engine and to see if your heater core is leaking? I know you can add some UV dye to the coolant and drive around for a while and look for it with a UV light to make sure it's not leaking in some hidden area and evaporating on you.
Oh, and double check your radiator cap isn't broken or anything.
https://linustechtips.com/topic/394837-emergency-car-help/#findComment-5327686
I can take it to a local mechanic. I will do that. I like to have an idea before I got in there :)
https://linustechtips.com/topic/394837-emergency-car-help/#findComment-5327700
Maybe they can pressure test your entire system too, just to be complete certain of where the coolant is going. But if you're sometimes having problems making power, it could be a gasket leak in to the cylinder(s).
https://linustechtips.com/topic/394837-emergency-car-help/#findComment-5327706
It was making power then I went to merge and since the red (Not yellow) engine light came on. I have had less power than my old 1.0L Sentra.
https://linustechtips.com/topic/394837-emergency-car-help/#findComment-5327713
Yeah it sounds like it's leaking in to your block. Which could be a head gasket you need to replace (yay!) or a cracked block (oh shit!). It's probably just a gasket. Might be a very old one too at that.
https://linustechtips.com/topic/394837-emergency-car-help/#findComment-5327728
Cracked block would total my car. It is worth less than 4K... for that matter a gasket might :(
https://linustechtips.com/topic/394837-emergency-car-help/#findComment-5327736
It's more than likely a head gasket. If the block were cracked you'd be seeing a lot of fun colors and smells coming out of your exhaust, along with some interesting noises.
https://linustechtips.com/topic/394837-emergency-car-help/#findComment-5327745
Interesting noises I have... sounds like I have somthing stuck under my car once in a while when I floor it xD Griding ish sound.
https://linustechtips.com/topic/394837-emergency-car-help/#findComment-5327753
it does should like a head gasket. It not the hardest job. Getting to it sucks and thats why it cost so much. Of this has been happening for some time you might need to get the cylinders honed.
https://linustechtips.com/topic/394837-emergency-car-help/#findComment-5327771
