Okay, so I livestream. And I have the fastest speed internet I can get from Comcast. (About 60Mb down and 7Mb up.) the 7Mb restricts me to streaming at 720p30fps. I'm getting a new PC now and I'm wondering if I get one with dual network ports, would I technically have 14Mbs up? If not could I combine a Wifi card and the dual or single LAN? Thanks for any help:)
https://linustechtips.com/topic/393936-dual-lan/
-_- logic
you pay for 7 up your only getting 7 up.
even if you bought another line of internet
programs can't use 2 lines at once (unless torrenting)
you can only redirect program through one port or another.
https://linustechtips.com/topic/393936-dual-lan/#findComment-5316028
no, two ports does not make a difference
the bottleneck is your ISP not your ethernet ports
ethernet ports can do 1000Mbps which is WAY more than youre even getting
https://linustechtips.com/topic/393936-dual-lan/#findComment-5316062
You could try this:
How unintelligent are u?
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
https://linustechtips.com/topic/393936-dual-lan/#findComment-5316076
No shit sherlock.
I'd like to return that question to you, as you apparently are unable to understand sarcasm.
i was concerned that some people might believe this guy, and would fuck up their internet cables... :(
https://linustechtips.com/topic/393936-dual-lan/#findComment-5318965
