It can do, but will depend on the speakers. If you have £20 speakers, they'll still sound bad, even with a DAC.
One of the main benefits is just getting the signal away from your PC, so you don't get noise and interference, but with speakers, you're going to lose some of the quality, just by the nature of them. You don't get the isolation and accuracy of headphones, unless you're in a studio environment.
https://linustechtips.com/topic/393784-dacs-and-speakers/#findComment-5314089
Only if you get passive speakers that don't have a DAC and amp on board. Otherwise just ditch the amp and go for active speakers.
My speaker is a UE Boom, does it work with that?
"Just go Android (Glorious Android Masterrace)"
Phone: Samsung Galaxy S6 Edge 64GB
PC "SkyT": Radeon 390, i5 6600K, NZXT H440 Razer
https://linustechtips.com/topic/393784-dacs-and-speakers/#findComment-5314273
https://linustechtips.com/topic/393784-dacs-and-speakers/#findComment-5314276
No. Those are wireless. You'd need wired speaker to use an external DAC. They're also not very good sound quality, so there wouldn't be any noticeable improvement anyway.
I'm using it wireless
https://linustechtips.com/topic/393784-dacs-and-speakers/#findComment-5314369
lol im a loser, I meant I use it wired
No matter if you have a DAC or not. Wireless or wired. Those speakers are going to sound horrible.
"I believe that if life gives you lemons, you should make lemonade... And try to find somebody whose life has given them vodka, and have a party."
-Ron White
https://linustechtips.com/topic/393784-dacs-and-speakers/#findComment-5316032
why?
They're just overall bad speakers, no amount of DAC can fix that. I would invest in some better speakers.
-Ron White
https://linustechtips.com/topic/393784-dacs-and-speakers/#findComment-5316717
Ehm the ue boom are really good €200 speakers
https://linustechtips.com/topic/393784-dacs-and-speakers/#findComment-5319081
There are much better speakers for 200 euro
Nope, this is the best combination, sound quality + looks + battery + connectivity, the bose soundlink mini's battery is worse and the Bluetooth connectivity is bad en it only sounds a bit better
https://linustechtips.com/topic/393784-dacs-and-speakers/#findComment-5320007
That's just not true. Not at all.
I worded that badly. Obviously speakers can be accurate and receive the full signal, but as they're not isolating other noises like headphones can, in most cases there'll be other noises that get mixed with the music. So the hum of your PC, noises outside etc. If they're being used in a studio environment, then that's different situation.
https://linustechtips.com/topic/393784-dacs-and-speakers/#findComment-5320776
Most high-end headphones are open, simply because they have better imaging and sound staging. HD800, touted being one of the best headphones in the world was aimed to sound like a speaker, not a headphone
https://linustechtips.com/topic/393784-dacs-and-speakers/#findComment-5321061
They may be the best shitty bluetooth mobile portable speakers you can buy on the market right now.... but those are all bad.
-Ron White
https://linustechtips.com/topic/393784-dacs-and-speakers/#findComment-5322951
Xtroria is right about this. A friend of mine has the UE boom. It's a decent speaker for a small wireless one, but it definitely is not very good sound-wise for the money. Honestly, the big jambox sounds much better, and as I recall it's not all that much more expensive, at least if you buy it used. Regardless, there aren't really any bluetooth systems that sound good. The bandwidth is too low.
Hey! New SIgnature!
I'm supposedly a person on the Internet, but you'll never know if I'm human or not ;)
https://linustechtips.com/topic/393784-dacs-and-speakers/#findComment-5323300
No, no portable bluetooth speaker will benifit from an external dac (to an extent, there are pobablly exceptions)
Only speakers that COULD benifit from a dac would be non portable 2.0/2.1/5.1/7.1 and ect sound systems/speakers
https://linustechtips.com/topic/393784-dacs-and-speakers/#findComment-5323544
Don't be such anti logitech, so immature, it's a fact that this is one of the better.
https://linustechtips.com/topic/393784-dacs-and-speakers/#findComment-5323588
