anyone here know of a good controller for these types of games on PC?
saints row
minecraft
civilization
hitman absolution
portal
im thinking of going with the ps4 controller because im not a fan of the analog sticks on the xbox controllers. any recommendations?
Rigs I've Built
The Striker i5 4590 @ 3.7 ||  MSI GTX 980 Armor X2 || Corsair RMX 750 || Team Elite Plus 8 GB || Define S || MSI Z97S SLI Krait
The Office PC i3 4160 @ 3.6 || Intel 4600 || EVGA 500B || G.Skill 8 GB || Cooler Master N200 || ASRock H97M Pro4
The Friend PC G3258 @ 4.3 || Sapphire R9 280X Tri-X || EVGA 600B || 8 GB Dell Ram || Cooler Master N200 || ASRock H97M- iTX/ac
The Mom Gaming PC A10-7890K @ 4.4 || iGPU + ASUS R7 250 ||  8 GB Klevv DDR3-2800 Mhz
https://linustechtips.com/topic/393151-best-controller-for-pc/
Minecraft  has no controller support, FYI
An Xbox One / 360 controller has native support. I use it for GTA V which has poopy Keyboard controls.
NCASE M1 i5-12600kf  RTX 4060Ti FE Z690M-ITX  SF600 NH-L9x65 Chromax  LPX 32GB
https://linustechtips.com/topic/393151-best-controller-for-pc/#findComment-5305621
When you ask a PC gamer if they use a controller and which one they use, more often than not they will say either the Xbox 360 or Xbox One controller. But the Steam controller imo will be a better choice for the games you have listed.
https://linustechtips.com/topic/393151-best-controller-for-pc/#findComment-5305655
Xbox One imo
Its what I use in GTA V
Although PS4 is nice too!
xbox one or xbox 360 is your best bet IMO by a long shot, best support
I use a XBox 360 Controller now for over 3 years which works really well.
It's so easy to use and feels great.
please reread the the op, as it clearly states that im not a fan of the xbox 360 layout so any other recommendations?
Rigs I've Built
https://linustechtips.com/topic/393151-best-controller-for-pc/#findComment-5305672
I did read the OP. The PS3/PS4 controllers have no support and require you to buy a bluetooth dongle, fake the pairing of the Controller to the PC instead of the PS3 and then use 3rd party apps to basically trick windows into thinking it's an xbox controller. You'll need to map the controller for every. single. game.
I'm a PS2, PS3, PS4 user who has never owned an Xbox device. I bought an Xbox 360 controller.
There are Razer etc Keypads too, but they are modeled after the Xbox ones.
Just go Xbox if you want 100% native support.
https://linustechtips.com/topic/393151-best-controller-for-pc/#findComment-5305695
i just use a wired x-box 360 one and its nice
Builds:
https://linustechtips.com/topic/393151-best-controller-for-pc/#findComment-5305697
A controller for minecraft!? wut? Anyway, you'll probably have the least trouble getting an xbox controller to work with your games... it is debatable whether it's the 'best' but it's probably the least hassle
 CPU:  Intel i7-4790K      Cooler:  Noctua NH-D14     GPU: ZOTAC GTX 1070 TI MINI     Motherboard:  ASUS Z97 Gryphon     RAM:  32GB G Skill Trident X
Storage: 2x 512GB Samsung 850 EVO (RAID 0) / 2TB Seagate Barracuda     PSU: 850W EVGA SuperNova G2     Case: Fractal Design Node 804
https://linustechtips.com/topic/393151-best-controller-for-pc/#findComment-5305700
Civ is going to be the real challenge, and supposedly the Steam controller with the touchpads works great for games like that.  Otherwise the other controller that I don't think anyone's mentioned here yet is the Nvidia Shield controller which works with PC's (have to use it wired though).  Granted the layout is fairly similar to the 360 controller but you get things like a trackpad to control your mouse curser, volume control, and a thumbstick that feels more sensitive (i personally prefer the 360 thumbstick, but without knowing why you don't like the xbox thumbsticks at least the Shield controller feels different)
https://linustechtips.com/topic/393151-best-controller-for-pc/#findComment-5305798
Then better get used to an XBox controller, cause it is the only one that will work every single time with Windows cause it is supported directly by Microsoft.
https://linustechtips.com/topic/393151-best-controller-for-pc/#findComment-5307662
umm, no you don't, it works just like a 360/ xbox one controller would. I know because I've used a ps3 controller before to play watchdogs and sleeping dogs on the pc. Also you can use a usb cable instead of buying a Bluetooth adapter.
CPU: AMD Ryzen 9 3900x  GPU: ASUS Strix rtx 2080 Super RAM: Corsair Vengeance Pro RGB 8gb x4 PSU: Corsair HX850i Motherboard: ASUS Strix x570-E Storage: Samsung 840 pro, Samsung 970 evo 1tb nvme, segate 2tb Case: NZXT H510I Cooling: Corsair h100i
https://linustechtips.com/topic/393151-best-controller-for-pc/#findComment-5307787
I prefer the 360 controller or snes controller.
Or a Wii u controller
Intel 4670K /w TT water 2.0 performer, GTX 1070FE, Gigabyte Z87X-DH3, Corsair HX750, 16GB Mushkin 1333mhz, Fractal R4 Windowed, Varmilo mint TKL, Logitech m310, HP Pavilion 23bw, Logitech 2.1 Speakers
https://linustechtips.com/topic/393151-best-controller-for-pc/#findComment-5307865
Xbone controllers are pretty shit quality especially when it comes to drifting
https://linustechtips.com/topic/393151-best-controller-for-pc/#findComment-5307937
You should be just fine with the DualShock 4; just get some sort of third-party software, and optionally an add-on that for regular Bluetooth, and you are good to go.
If you are willing to venture into game-pads, get the Logitech RumblePad 2 if you can find it.
Read the community standards; it's like a guide on how to not be a moron.
Gerdauf's Law: Each and every human being, without exception, is the direct carbon copy of the types of people that he/she bitterly opposes.
Remember, calling facts opinions does not ever make the facts opinions, no matter what nonsense you pull.
https://linustechtips.com/topic/393151-best-controller-for-pc/#findComment-5308284
Thank you all for your comments, and i think ill go with the dual shock 4.thanks to me before mapping the wii u tablet controller for pc, i was able to learn how to use glovepie, software to map controller functions over Bluetooth. i have no problem coding ( and yes, its not drag and drop, it is programming)  for every game i want to play. thank you all gentlemen of the internet for your advice!
Rigs I've Built
https://linustechtips.com/topic/393151-best-controller-for-pc/#findComment-5308379
Just saying that Minecraft PC can only be controlled with Keyboard and Mouse, without the use of old mods that wont let you play on multiplayer.
My PC/ CPU: Intel i5-4690k with ColerMaster Hyper Evo 212 / Motherboard: Asus Z97-AR GPU: EVGA GeForce GTX 750 Ti / OS: Windows8.1 / RAM: G.Skill Ares Series 2x4 1600Mhz / Storage: Seagate Barracuda 1TB 7200RPM Optical Drive: ASUS 24B1ST / Network: TP-Link WN881ND /////////////////////////// If I fail to respond to your questions, please message me! Thank you
https://linustechtips.com/topic/393151-best-controller-for-pc/#findComment-5308383
