Hello,
I am looking for a keyboard. Doesnt matter if it is membrane or mechanical.
I use my computer for graphic design, 3D design, rendering, animation, movie making and gaming.
I am using a Dell L100 at home on my pc and it seems to be fine for me. It has the clicking sound and seems to get good response. I dont know if it is good response or not becuase I have not really used any other keyboard except for the cheap ones at work and I think they are cheaper Dell keybaord. I havent really paid attention to them.
I cant buy a expensive keyboard at the moment.
I am looking at the Ttele sports Challenger Prime.    Is this too cheap and not so good?  The reviews seem to be 50/50.
Should I wait to buy a more expensive keyboard?   What other alternatives should I look at?
I use my pc for work listed first and gaming second.
https://linustechtips.com/topic/391999-help-with-choosing-a-keyboard/
Hello,
If you enjoy your keyboard then why replace it? I don't know what you'll like.
Best advice i can give you is to go to a store that sells them and try it out. If in America, best buy always has keyboards out.
LINK-> Kurald Galain:  The Night Eternal
Top 5820k, 980ti SLI Build in the World*
CPU: i7-5820k // GPU: SLI MSI 980ti Gaming 6G // Cooling: Full Custom WC //  Mobo: ASUS X99 Sabertooth // Ram: 32GB Crucial Ballistic Sport // Boot SSD: Samsung 850 EVO 500GB
Mass SSD: Crucial M500 960GB  // PSU: EVGA Supernova 850G2 // Case: Fractal Design Define S Windowed // OS: Windows 10 // Mouse: Razer Naga Chroma // Keyboard: Corsair k70 Cherry MX Reds
Headset: Senn RS185 // Monitor: ASUS PG348Q // Devices: Note 10+ - Surface Book 2 15"
LINK-> Ainulindale: Music of the Ainur
Prosumer DYI FreeNAS
CPU: Xeon E3-1231v3  // Cooling: Noctua L9x65 //  Mobo: AsRock E3C224D2I // Ram: 16GB Kingston ECC DDR3-1333
HDDs: 4x HGST Deskstar NAS 3TB  // PSU: EVGA 650GQ // Case: Fractal Design Node 304 // OS: FreeNAS
