I am building a new rendering pc for a friend of mine, but When I try booting it up, it turns on, but the fans run REALLY slow, and then it shuts down, just to turn on again with the same results.
These are the parts i'm using:
CPU: core i7 4790K
GPU: Quadro K4000
MB: Gigabyte B85N Phoenix
PSU: Corsair CX500M
RAM: x2 8GB Hyper X Fury @ 1600MHz
HDD: Hitachi Deskstar
ZamoRIG 2.0:
Processor: AMD Ryzen 7 1700 @ 3.9GHz
Cooling: DeepCool Captain 240 RGB + 2x Corsair ML120 fans
Graphics Card: Gigabyte GTX 1070 G1 Gaming x2
Motherboard: Asrock X370 Gaming K4
RAM: 2x8GB DDR4 G Skill Ripjaws V Grey @ 2800MHz
SSDs: 2xPatriot Ignite M.2 240GB
HDD: WD Black 1TB + WD Green 2TB
 PSU: Corsair RM750
Case: Corsair Carbide 400C
ZamoRIG “Portable”:
Processor: AMD Ryzen 5 1600 @ 4GHz
Cooling: Corsair H80i
Motherboard: Gigabyte AB350N Gaming WiFi
RAM: 1x16GB DDR4 Corsair Vengance  @ 2400MHz
SSD: Patriot Ignite M.2 240GB
HDD: 2TB 2.5” Seagate HDD
PSU: Corsair TX650M
Case: Siverstone SG13
https://linustechtips.com/topic/391865-trouble-with-new-build-help-please/
I'm no expert but is bios updated lol?
i7-6700k  Cooling: Deepcool Captain 240EX White GPU: GTX 1080Ti EVGA FTW3 Mobo: AsRock Z170 Extreme4 Case: Phanteks P400s TG Special Black/White PSU: EVGA 850w GQ Ram: 64GB (3200Mhz 16x4 Corsair Vengeance RGB) Storage 1x 1TB Seagate Barracuda 240GBSandisk SSDPlus, 480GB OCZ Trion 150, 1TB Crucial NVMe
(Rest of Specs on Profile)
dunno, just took the parts out of the box and stuck the together (properly I believe)
ZamoRIG 2.0:
 PSU: Corsair RM750
ZamoRIG “Portable”:
PSU: Corsair TX650M
Wait u have a "K" cpu and a B85 motherboard? whats ur logic?
U need to update the bios b4 u use the CPU with the motherboard. Tat board is not compatible with a 4690k out of the box usuallly.
Laptop: Thinkpad W520 i7 2720QM 24GB RAM 1920x1080 2x SSDs Main Rig: 4790k 12GB Hyperx Beast Zotac 980ti AMP! Fractal Define S (window) RM850 Noctua NH-D15 EVGA Z97 FTW with 3 1080P 144hz monitors from Asus Secondary: i5 6600K, R9 390 STRIX, 16GB DDR4, Acer Predator 144Hz 1440P
As Centos 7 SU once said: With great power comes great responsibility.
Do you have another CPU laying around that is compatable with a b85 mobo? Also if not return it and get a z97 mobo to overclock the 4790k
I mean, it doesn't even POST
ZamoRIG 2.0:
 PSU: Corsair RM750
ZamoRIG “Portable”:
PSU: Corsair TX650M
thank you for your help, It turns out that the MB was busted, so I got a new one under warranty : )
ZamoRIG 2.0:
 PSU: Corsair RM750
ZamoRIG “Portable”:
PSU: Corsair TX650M
