there are no 128 bit cpus and applications
well he could buy and itanium pc for laughs...
Everything you need to know about AMD cpus in one simple post.  Christian Member
Wii u, ps3(2 usb fat),ps4
Iphone 6 64gb and surface RT
Hp DL380 G5 with one E5345 and bunch of hot swappable hdds in raid 5 from when i got it. intend to run xen server on it
Apple Power Macintosh G5 2.0 DP (PCI-X) with notebook hdd i had lying around 4GB of ram
TOSHIBA Satellite P850 with Core i7-3610QM,8gb of ram,default 750hdd has dual screens via a external display as main and laptop display as second running windows 10
MacBookPro11,3:I7-4870HQ, 512gb ssd,16gb of memory
https://linustechtips.com/topic/391730-64bit-spu-and-128bit-cpu/#findComment-5287209
Hi!
ca i run a 128bit cpu on my laptop. At the moment i have a 64bit cpu on it
  1. There are no commercially available 128-bit CPUs
  2. Also, why?
Incipere V5.0
CPU | i7-4790k | GPU | Nvidia GTX Titan X | Motherboard | MSI Z97S SLI Krait Edition | Memory | 2x8GB Kingston HyperX Fury DDR3 1866MHz | PSU | EVGA 650 G2 | Storage | Crucial BX200 240GB + Toshiba 3TB | Case | Cooler Master MasterCase Pro 5 | CPU Cooler | Noctua NH-D15
Parvulus V1.0
CPU | i5-4690k | GPU | Zotac GTX 960 | Motherboard | ASRock Z97M-ITX/ac | Memory | 2x4GB G.Skill Ripjaws X DDR3 1600MHz | PSU | EVGA 650 GS | Storage | Crucial BX200 240GB + WD 1TB Blue 2.5" | Case | Silverstone Sugo SG13
If you want to join a group chat of like-minded techies, gaming, and all things dank, join our Discord group. Message me or get into contact with Galaxy. http://linustechtips.com/main/user/107351-gaiaxy/
https://linustechtips.com/topic/391730-64bit-spu-and-128bit-cpu/#findComment-5287225
  1. Also, why?
Because 2^64 bytes of RAM isn't enough for Minesweeper.
PSU Tier List | CoC
Gaming Build | FreeNAS Server
https://linustechtips.com/topic/391730-64bit-spu-and-128bit-cpu/#findComment-5287232
i mean what is the diffrence between 64bit fpu widt and 128bit fpu width and wath is fpu width
What exactly is it that you want to know? What hardware are you looking at?
PSU Tier List | CoC
https://linustechtips.com/topic/391730-64bit-spu-and-128bit-cpu/#findComment-5287239
my cpu is amd athlon II dual core m320 and i need a new and better one
buy a new computer
PSU Tier List | CoC
https://linustechtips.com/topic/391730-64bit-spu-and-128bit-cpu/#findComment-5287279
why is it so bad
Because it's a 6 year old dual core cpu......
PSU Tier List | CoC
https://linustechtips.com/topic/391730-64bit-spu-and-128bit-cpu/#findComment-5287297
why is it so bad
because its a really shity and old CPU
Builds:
https://linustechtips.com/topic/391730-64bit-spu-and-128bit-cpu/#findComment-5287312
The performance of a CPU is not determined by the number of 'bits' it has (generally), it does affect the amount of RAM that it can address. So whilst a 32-bit CPU can only address 232 bytes of RAM (i.e. 4GB of RAM), a 64-bit CPU can address 264 bytes of RAM, which is approximately 18 billion Gigabytes of RAM.
Your poor performance would be due to an ageing architecture with low instructions per cycle, and a low clock speed.
A CPU upgrade would be recommended.
Incipere V5.0
Parvulus V1.0
https://linustechtips.com/topic/391730-64bit-spu-and-128bit-cpu/#findComment-5287316
Hi!
As it is a laptop, you cannot even swap out the CPU for another without some pretty intense soldering. Most laptops aren't designed for the end-user to do much beyond throwing in another RAM module or swapping out the hard disk/SSD. For a new CPU, practically speaking, you need a new laptop.
And like the others said, there are no commercially available 128-bit CPUs. I've never even heard of one that isn't commercially available, personally.
https://linustechtips.com/topic/391730-64bit-spu-and-128bit-cpu/#findComment-5287445
