Hey guys, this is a list of my entire PC setup, is there anything I'm missing or overpaying for? I'd like to reduce the price a tad but don't know what I can hold back on without sacrificing a lot of performance (eg. Getting a GTX 970 vs. a 980). I don't need a supercomputer, but I want to play games like Metro and BF4 on good settings. Thanks!!
Here's the list:
Intel Core i7 4790K
Bitspower CPU Summit EF Waterblock
12 Primochill 1/2" OD Rigid GHOST Compression Fittings
Primochill 1/2" OD Clear Rigid Tubing
EVGA GTX 980 ACX 2.0 4GB
EK GTX 980 Strix Waterblock
EK GTX 980 Strix Backplate (Black)
EK D5 X-RES Top 100 Acetal
Alphacool NexXxos ST30 Slim Profile Dual 140mm Radiator
Alphacool NexXxos ST30 Slim Profile Dual 120mm Radiator
MSI Z97S SLI Krait Edition Motherboard
NZXT HALE90 V2 1200w PSU
Kingston HyperX FURY 8GB Kit White
NZXT H440 White Mid Tower Case
Samsung 850 Pro Series 128GB SSD
Seagate Hybrid Drive 2TB SHDD
Samsung DVD Writer 24X
https://linustechtips.com/topic/390497-computer-checklist-help/
PLEASE
HAVE MERCY WITH THE BALLER PSUs
Get an EVGA 850G2, you can SLI 2 Titan Xs on 850w You'll probably save enough money to double your RAM to 16gb
Nude Fist 1: i5-4590-ASRock h97 Anniversary-16gb Samsung 1333mhz-MSI GTX 970-Corsair 300r-Seagate HDD(s)-EVGA SuperNOVA 750b2
Name comes from anagramed sticker for "TUF Inside" (A sticker that came with my original ASUS motherboard)
https://linustechtips.com/topic/390497-computer-checklist-help/#findComment-5271236
Here's the list:
Intel Core i7 4790K
Follow your own posts.
Use http://pcpartpicker.com
Use [bb] codes for showing your setup on PCPartPicker
Welcome!
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/390497-computer-checklist-help/#findComment-5271238
PLEASE
Haha alright, I'm just coming from a weaker setup with a 1000w, so I assumed I needed more
https://linustechtips.com/topic/390497-computer-checklist-help/#findComment-5271267
Welcome to the Forum.
Please use http://pcpartpicker.com
Also, what are you wanting to do with the build, what's your budget and what's your location?
Budget is under 3 grand, but I'd like to keep it as low as possible and it'll be strictly for gaming
https://linustechtips.com/topic/390497-computer-checklist-help/#findComment-5271276
Well you can probably re purpose the 1000w. Do you know the brand/efficiency rating? And with that budget you should be able to fit a 980TI or Fury X. The Fury X seems to perform a little better than the 980ti and I think it comes water cooled. But you'd have to wait for the Fury X to be released, it shouldn't be too long
https://linustechtips.com/topic/390497-computer-checklist-help/#findComment-5271286
Yeah a slight issue here...
https://linustechtips.com/topic/390497-computer-checklist-help/#findComment-5271294
What's that?
Those strix blocks do not fit that card.
https://linustechtips.com/topic/390497-computer-checklist-help/#findComment-5271316
I'm completely selling my old pc, so I'm starting from scratch here :/
There's also no optical drive slot on the H440
https://linustechtips.com/topic/390497-computer-checklist-help/#findComment-5271329
It said it had a physical match, is that not enough?
Better getting the right block for that card.
What EVGA 980 specifically? Sine there's variations of the cards.
Either that or you've selected that wrong card.
https://linustechtips.com/topic/390497-computer-checklist-help/#findComment-5271339
Your budget is insane man. If you forget about the crazy (and unnecessary) water cooling setup you can get a whole new computer that performs better, and an amazing monitor, and an OS
http://pcpartpicker.com/p/9JDFnQ
https://linustechtips.com/topic/390497-computer-checklist-help/#findComment-5271354
I have that exact PSU and it has been great, can't hear it and Johnny guru gave it a great rating. MAYBE the cables are not the prettiest if that's a concern, but the point anyway is a single 980 and a 4790k don't need much power, you could probably get away with 700ish
System
  • CPU
    I7-4790K @ 4,7GHz
  • Motherboard
    Asus MAXIMUS Formula VI
  • RAM
    Kingston HyperX FURY 16GB Kit (2x8GB) 1866MHz
  • GPU
    MSI GTX 1070 Gaming X
  • Case
    Cooler Master Cosmos SE
  • Storage
    Samsung 840 EVO 500GB+WD Green 3TB
  • PSU
    EVGA SuperNOVA 850G2 80PLUS Gold Certified
  • Display(s)
    ASUS PB277Q 27" WQHD 2560x1440 75Hz 1ms
  • Cooling
    Corsair H105 with AP121s and Phanteks fans
  • Keyboard
    Logitech G610 Orion
  • Mouse
    E-3lue E-Blue Mazer II 2500 DPI Blue LED 2.4GHz Wireless Optical Gaming Mouse
  • Sound
    Audio-Technica ATH-M20x
  • Operating System
    Windows 10
https://linustechtips.com/topic/390497-computer-checklist-help/#findComment-5271369
Sweet, that should save some cash to sleeve the cables if they're that bad xD
https://linustechtips.com/topic/390497-computer-checklist-help/#findComment-5271393
Just the standard base model, and the evga block was cool but a bit pricey
That HydroCopper card is what you may have saw.
EK do make EVGA blocks. They may not have the EVGA logo on them but they fit.
https://linustechtips.com/topic/390497-computer-checklist-help/#findComment-5271395
Here's the list:
Intel Core i7 4790K
You said $3,000 budget, right?
Motherboard: Gigabyte GA-Z97N-Gaming 5 Mini ITX LGA1150 Motherboard  ($128.99 @ SuperBiiz)
Video Card: EVGA GeForce GTX Titan X 12GB HYBRID Video Card  ($1099.99 @ Amazon)
Case: BitFenix Prodigy (Black) Mini ITX Tower Case  ($77.99 @ SuperBiiz)
Monitor: Acer G257HL BMIDX 60Hz 25.0" Monitor  ($159.99 @ Micro Center)
Keyboard: Corsair Vengeance K70 Wired Gaming Keyboard  ($119.95 @ Amazon)
Mouse: Mad Catz R.A.T. 7 Wired Laser Mouse  ($99.99 @ NCIX US)
Headphones: Beyerdynamic DT 990 Pro 250  Headphones  ($209.69 @ Amazon)
Other: MXL 770 Cardioid Condenser Microphone ($78.99)
Other: NEEWER Microphone Suspension Boom Scissor Arm Stand ($13.20)
Other: Flexible Studio Microphone Mic Wind Screen Pop Filter Mask Shied Double Layers ($3.44)
Total: $3000.00
Generated by PCPartPicker 2015-06-20 17:20 EDT-0400
https://linustechtips.com/topic/390497-computer-checklist-help/#findComment-5271460
