GTA V Low FPS or Normal?
lovingGamer
Okay, this seems little bit weird to me that i'm getting 20-30 FPS when i'm in a Car or driving it, i can't even get constant 35 FPS. Sometime if i'm lucky i get like 50 FPS
Specs
I3 4150
8 GB of RAM
MSI r9 280x
My settings:
Resolution: 1050p
FXAA: off
MSAA: off
Texture quality: Very High
Shader quality: Normal
Shadow Quality: High
Reflection quality: High
Reflection MSAA: off
Water quality: Normal
Particles quality: Normal
Grass Quality: normal
Soft shadows: sharp
POST FX: Normal
Ambient Occlusion: normal
Tessellation: normal
Anisotropic filtering: X4
Thanks
Have you... I dunno... Tried to turn down the settings?
I feel like that Duo Core i3 is a Bottleneck
No way. Not for 280x.
Because he had a hard drive.
yes to the lowest and same i can't get stable 40 FPS
really huh...
really huh...
It is a Duo Core
Your GPU should be fine
It is a Duo Core
Sure?
It is a Duo Core
it's not a dual core to the game.
It is a Duo Core
Uhm... look at the recommended specs for GTA V.
Drivers etc all up to date?
NCASE M1 i5-9600k  GTX 1080 FE Z370N-WIFI SF600 NH-U9S LPX 32GB 960EVO
I'm a self-identifying Corsair Nvidia Fanboy; Get over it.
AMD yes i guess
Specs
I3 4150
8 GB of RAM
MSI r9 280x
My settings:
Resolution: 1050p
FXAA: off
MSAA: off
Soft shadows: sharp
POST FX: Normal
Thanks
have you installed amd drivers 15.5 beta that helped my friend with low fps.
then what is it? and how to fix it
My driver version is 9.14.10.01080 Catalyst 14.12
i did
install the beta drivers and then come back tot he forum. my friend had 14.12 but gta ran like shit the beta made it playable for him
That is GTA V, i saw that GTX750Ti is better than 280.
Nvidia Drivers are a lot better for GTA V
Do you maybe know what FPS it was? 40-50??
Try this beta driver. http://forums.guru3d.com/showthread.php?t=399956
Also, turn off everything in Advanced settings and lower the density and distance scaling slider.
Remember to use DDU.
i did
They recommend an i5... so the i3 is a bottleneck. But getting low FPS while driving is pretty normal.
he was getting like 20 it was unplayable. he installed 15.5 and everything went buttery smooth he said.
that driver fucked up my PC!
Big time! GPU temps it's showing 0 everything is 0
My PC is working like it doesn't have GPU!!
Did you restart? Did you check Device Manager whether it show R9-200 or it show Standard Graphic blablabla?
I see that you are using very high texture settings, what is the performance with them set to high or medium?
Asus B85M-G / Intel i5-4670 / Sapphire 290X Tri-X / 16GB RAM (Corsair Value 1x8GB + Crucial 2x4GB) @1333MHz / Coolermaster B600 (600W) / Be Quiet! Silent Base 800 / Adata SP900 128GB SSD & WD Green 2TB & SG Barracuda 1TB / Dell AT-101W / Logitech G502 / Acer G226HQL & X-Star DP2710LED
