Building environment
Go to solution Solved by Snickerzz,
Just touch your PSU/radiator every so often to get rid of any static electricity. As for the cat hair curtain, close the window so there isnt really any moving air to blow the cat hair around.
And put the CPU in the mobo with the mobo on the box, not the table.
Hello, so I ordered my PC and it will come a few days. I've watched a few Linus build guides and all of them mention some kind of wrist strap and an anti-static mat.
I was thinking that I'll be building on my wooden desk, take away my carpet so I don't stand on it and touch the old-school metal radiator in my room.
Is the wrist strap and mat really important building a computer?  Should I use motherboard box or just the table when installing CPU on motherboard?
And my desk is next to a window which curtains are full of cat hair and it's very "staticky", will that be bad?
P.S. I was going to some shops but none of the shops in my city had those straps.
https://linustechtips.com/topic/389532-building-environment/
Nope, you just need to properly ground yourself first.
See my blog for amusing encounters from IT workplace: http://linustechtips.com/main/blog/585-life-of-a-techie/
https://linustechtips.com/topic/389532-building-environment/#findComment-5259446
Case: NZXT Phantom PSU: EVGA G2 650w Motherboard: Asus Z97-Pro (Wifi-AC) CPU: 4690K @4.2ghz/1.2V Cooler: Noctua NH-D15 Ram: Kingston HyperX FURY 16GB 1866mhz GPU: Gigabyte G1 GTX970 Storage: (2x) WD Caviar Blue 1TB, Crucial MX100 256GB SSD, Samsung 840 SSD Wifi: TP Link WDN4800
Donkeys are love, Donkeys are life.                    "No answer means no problem!" - Luke 2015
https://linustechtips.com/topic/389532-building-environment/#findComment-5259452
if you REALLY want to be carefull go for the wriststrap/ankle strap same thing
touch the case to remove the electrity from ur body
for shits and giggles but actually works take off ur clothes (i did it :) )
https://linustechtips.com/topic/389532-building-environment/#findComment-5259458
Okay, thanks, it seems to explain everything I wanted. Thank you!
https://linustechtips.com/topic/389532-building-environment/#findComment-5259484
If you have a metal case, you can ground yourself to that as well. Test fitting on the MOBO box is always the best way (it fits on it perfectly). As for static, don't worry. You'll be fine. Don't make it rocket science. HAVE FUN!
Intel Core i7-6700K | Corsair H105 | Asus Z170I PRO GAMING | G.Skill TridentZ Series 16GB | 950 PRO 512GB M.2
Asus GeForce GTX 980 Ti 6GB STRIX OC | BitFenix Prodigy (Black/Red) | XFX PRO Black Edition 850W
My BuildPCPartPicker | CoC
https://linustechtips.com/topic/389532-building-environment/#findComment-5259491
