Ultra or High Settings
I have already written about games i meant.
They are=
Battlefield Series
Far Cry Series
Call Of Duty Series
Medal Of Honor Series
Need For Speed Series
Series means latest or past 2-3years games
What I do is pick a preset and then mess with some settings individually and see which ones hurt performance hard and which I'd like to have. For instance, I'll select the ultra preset for a game, and then turn down MSAA to 4x (or even 2x), since I personally usually don't need or care for more than that. Then I'll see which shadow settings hurt performance a lot and turn them down if I need to. Then I go through the rest. I'll turn up Anistropic filtering if I can, and usually grass qualities/densities are a good place to get some performance if I need it. For some settings though, I'll keep them on if I think it adds enough to the image, like soft shadowing. Just find the settings you really like, and which ones hit performance hard, and then try to strike a balance.
Basically just do that and you'll be good to go. I usually don't have to change much though, as I have a 970 now.
