Optical Drive nearly touching the Motherboard?
Solved by Speakerator,
Is it really necessary to discuss whether or not OP may own a drive that is bound to short his board or not? There are hundreds of different drives out there, who cares....
OP, why don't you just fold around non-conductive tape around the edges of your drive? Even it is does touch your board any time in the future, it won't short out.
Pro-Benefit: electrical tape even makes plastic non-conductive
(though I do think that the edge of the board isn't that critical, BUT you get bragging right for a modded custom-color optical drive )
@Op2mus: next time please don't open two threads: http://linustechtips.com/main/topic/386994-optical-drive-nearly-touching-the-motherboard/
Though they managed to give a short answer there ^^
