Hi guys,
My pc is running slow for the last few days and it only has 2 weeks.
Example, when i move some windows for them to be in another place in my screen it lags, it move in "pieces". Programs take some time to open, some times the program crashes.
specs
mobo: gigabyte ud4 x99
cpu: i7 5280k
ram: hyperx 8g 2133 mhz
video: 980
HDD: seagate 2tb
psu: 850w cooler master V
windows 8.1
hope you guys can help me, if you need any other info let me know.
https://linustechtips.com/topic/386340-pc-going-sloow/
Did you defarg your drive? Have you tried doing a virus scan? Have you tried checking if your processor is busy with a unoptimised process in the task manager.
If you want to reply back to me or someone else USE THE QUOTE BUTTON!
Pascal laptops guide
https://linustechtips.com/topic/386340-pc-going-sloow/#findComment-5214633
when was the last time you clean installed windows
https://linustechtips.com/topic/386340-pc-going-sloow/#findComment-5214652
Hi guys,
specs
cpu: i7 5280k
video: 980
HDD: seagate 2tb
windows 8.1
get a ssd
PC is alive again! :System: CPU:Intel i5 4960k/ Motherboard:ASUS Gryphon Z97/ RAM: Kingston 16GB/ GPU: ASUS R9 Fury X/ Storage: 120gb Crucial SSD, 2TB Seagate SSHD/ PSU: Cooler Master 700w/ Displays: 1 Acer B276HK ymjdprz 27-inch 4K Ultra HD/1 ASUS 21.5 LCD LED 21.5 monitor
https://linustechtips.com/topic/386340-pc-going-sloow/#findComment-5214657
Hi guys,
specs
cpu: i7 5280k
video: 980
HDD: seagate 2tb
windows 8.1
Sounds like its time for a nice clean install of Windows!
Please spend as much time writing your question, as you want me to spend responding to it.  Take some time, and explain your issue, please!
If you need to learn how to install Windows, check here:  http://linustechtips.com/main/topic/324871-guide-how-to-install-windows-the-right-way/
Event Viewer 101: https://youtu.be/GiF9N3fJbnE
https://linustechtips.com/topic/386340-pc-going-sloow/#findComment-5214670
dont get it
What don't you get?  You have a very high end machine, any performance issues are going to be either in component compatibility or software.
https://linustechtips.com/topic/386340-pc-going-sloow/#findComment-5214871
