  So my nephew has been using my back up Pc for awhile now and I wanted to build him a "middle of the road" Pc, Most of the games he plays a lot of the Blizzard series of games, some FFXIV and a bunch of my Steam games like Skyrim, Fallout, City Skylines and others.
Heres the list, if you guys can dwindle the price a bit or theres something more appropriate I should look into im all ears. Some things to note, I can either get that CPU for under $150 or the I-3 4130 for under $90. Also the case is something we already have. An im still debating on a SSD just for the OS. .
http://pcpartpicker.com/p/Q4H2Mp
Thanks =)
https://linustechtips.com/topic/386171-my-nephews-first-pc/
change the Z97 mobo for an H97
YES, DEFINITELY GET THE SSD
change the 960 to a 2GB model, 4GB probably wont be necessary with the 960 :P
https://linustechtips.com/topic/386171-my-nephews-first-pc/#findComment-5212542
Why a Z97 motherboard if you are not going to overclock? Also, you should consider getting an R9 280x instead of a GTX 960
Project Pluto
i3 4170 MSI H97 PC Mate MSI R9 380 2GD5T @ 1095MHz Kingston HyperX Fury Blue 2x4gb @ 1600MhzWD 1TB Blue • be quiet! Pure Rock • NZXT S340 Black XFX TS 550w • BenQ GW2265HM
https://linustechtips.com/topic/386171-my-nephews-first-pc/#findComment-5212545
With the 280X you will get ~10-15% more fps compared to the GTX960.
I would get him a cheap 60GB ssd for the OS.
Maybe change the default download destination to the browser, and steam/battlenet to the HDD for him :)
System
CPU: Intel Core i7 5820K @4.5GHz - 1.230v  RAM: HyperX Fury DDR4 4x4GB 2666MHz  MB: MSI X99S SLI PLUS  CASE: NZXT H440  CPU-COOLER: Fractal Design Kelvin S24  PSU: Corsair RM1000W w/ white sleeved cable kit  GPU: MSI GeForce RTX 2070 ARMOR  MONITOR: LG 27GL850-B  STORAGE: Samsung 970 EVO 1TB M.2, Samsung 840 EVO 256GB,  WD Red 3TB
https://linustechtips.com/topic/386171-my-nephews-first-pc/#findComment-5212572
http://pcpartpicker.com/p/JscHt6Here's a quick edited list. You can swap the 280x for a 960 if you'd prefer that, but the 280x has more VRAM than a similar priced 960, with a larger memory bus and is a bit more powerful, so will likely last a bit longer.
PCs
Branwen (2015 build) - CPU: i7 4790K GPU:EVGA GTX 1070 SC PSU: XFX XTR 650W RAM: 16GB Kingston HyperX fury Motherboard: MSI Z87 MPower MAX AC SSD: Crucial MX100 256GB + Crucial MX300 1TB  Case: Silverstone RV05 Cooler: Corsair H80i V2 Displays: AOC AGON AG241QG & BenQ BL2420PT Build log: link
Netrunner (2020 build) - CPU: AMD R7 3700X GPU: EVGA GTX 1070 (from 2015 build) PSU: Corsair SF600 platinum RAM: 32GB Crucial Ballistix RGB 3600Mhz cl16 Motherboard: Gigabyte Aorus X570i pro wifi SSD: Sabrent Rocket 4.0 1TB Case: Lian Li TU150W black Cooler: Be Quiet! Dark Rock Slim
https://linustechtips.com/topic/386171-my-nephews-first-pc/#findComment-5212605
CPU: Intel Core i5-4440 3.1GHz Quad-Core Processor  ($163.95 @ SuperBiiz)
Motherboard: Asus Z87-A ATX LGA1150 Motherboard  ($61.98 @ Newegg)
Video Card: Sapphire Radeon R9 280X 3GB Video Card  ($192.98 @ Newegg)
Case: NZXT S340 (Black) ATX Mid Tower Case  ($54.99 @ NCIX US)
Total: $617.87
Generated by PCPartPicker 2015-06-13 18:41 EDT-0400
https://linustechtips.com/topic/386171-my-nephews-first-pc/#findComment-5212653
Thanks =)
heres a build that is similar but about 30$ cheaper and will give you more performance http://pcpartpicker.com/p/WhgBpg I don't know the color scheme so the blue mobo might clash but if it does there's probably a similar priced red one
Edit: nvm I checked and your sol if you want a red mobo without spending 100+ $$ but there is an all black option but it doesn't look all that high end. It's up to you though it is your build not ours
The Ninja (current gaming pc)  Case- h440 red/black cpu- i5-4690k@ 4.3ghz cooler- coolermaster hyper 212 evo moboGigabyte z97x-sli ram- adata xpg v.1 2x4gb 1600mhz gpu- asus strix gtx 970 hdd- wd blue 1tb ssd- kingston hyperx savage 240gb psu- evga 600b peripherals: mouse- razer death adder 2013 keyboard- corsair k70 with chery mx-reds headset- HyperX Cloud 2
my laptop- toshiba satelite p850, cpu- i7-3630qm ram- 8gb 1600mhz hdd- 1tb 5400rpm gpu- Nvidia gt630m 2gb
did you know we have a gun thread ? well we do
and a car thread !
https://linustechtips.com/topic/386171-my-nephews-first-pc/#findComment-5212809
  Well to be honest I wasn't sure if we would be upgrading his Pc to a OC version down the line. Though it does make sense to go with the H97 if hes going to be happy for a few years, then it wouldnt matter cause he would probably need a whole new system by then anyways.
 As for the radeon cards, I have had such bad luck with them they scare me. They failed very early on, the next one was DoA, the third died 4 months in. I got a GTX and never had another dead card since.
https://linustechtips.com/topic/386171-my-nephews-first-pc/#findComment-5213321
