what do you mean by 15 pin and 2 pin?
its a sata power cable
they are all the same
are you talking about a "sata power extension" ?
https://linustechtips.com/topic/385651-help-finding-a-cable/#findComment-5206512
Like this but only the 15 pin to the 2 pin part. It's for a built in fan hub on my case. Or would this 22 pin cable work?
https://linustechtips.com/topic/385651-help-finding-a-cable/#findComment-5206565
http://www.moddiy.com/products/Mini-PC-Mini-2%252dPin-to-SATA-Power-Cable.html
https://linustechtips.com/topic/385651-help-finding-a-cable/#findComment-5206600
