Sup sup guys,am going to be designing a bussiness card,need some suggestions on which software i should u,i dun really think i am going to be using photoshop cause there a learning curve to it,something that goods and a guys with alittle experience with designing can use,any help is appreciated
https://linustechtips.com/topic/382680-bussiness-card-design-help/
And a really wise man starts out with a pencil, and paper.....Seriously, it saves you a lot of time later if you know what you want, and have your layout worked out before you plug it into a computer.
After that, any decent graphics program will work. If you want to start out cheap, take a look at a program called GIMP. it's freeware.
haha,thx guys,nice tip,will do so
