Posted June 4, 2015 Hello all, I have recently built a desk with a glass surface and have two 27" monitors and a 22" monitor that i want to mount above the center of the two 27" ones. I want to build something myself but am drawing a blank on ideas and need a little help to get the ball roling. Yes, all three have vasa mounts. No, I cannot mount onto the desk. Also, side note, I will be building a server into the desk and yes there will be a build log(hopefully soon). Thanks ahead of time for all the suggestions and help. God Bless. Travis Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 4, 2015 stack some boxes, or use a shelf on the wall My Server - Update 1 - Update 2 - Update 3 - Update 4 Gaming Rig Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 4, 2015 Author I only have a few inches between wall and monitor and i am thinking something a little better looking then a shelf. Travis Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 4, 2015 I only have a few inches between wall and monitor and i am thinking something a little better looking then a shelf. Why not get an arm and wall mount them or get an aluminum stand. If you want to build something you could create a floating shelf or have a raised section on the desk that fits according to your monitors. Updated Modding FAQ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 4, 2015 followed , i too planning to do monitor stands ! Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 5, 2015 Author What I actually realized(not living there yet but fiance is) is that there is a small window at about the right height for me to clamp on a monitor arm onto the window sill. Thank you for all the input. Why not get an arm and wall mount them or get an aluminum stand. If you want to build something you could create a floating shelf or have a raised section on the desk that fits according to your monitors. I cannot wall mount. I am just renting the place. Thanks again. Travis Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 5, 2015 I cannot wall mount. I am just renting the place. Thanks again. They'll never know if you putty/sand/repaint before you move out My Server - Update 1 - Update 2 - Update 3 - Update 4 Gaming Rig Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 5, 2015 What I actually realized(not living there yet but fiance is) is that there is a small window at about the right height for me to clamp on a monitor arm onto the window sill. Thank you for all the input. I cannot wall mount. I am just renting the place. Thanks again. as said you can fill and repaint any holes, but if you need an alternative you can get triple monitor stands that are adjustable and all mount and sit on the desk surface: http://www.bit-tech.net/hardware/2011/07/24/xfx-triple-display-monitor-stand-review/1 Updated Modding FAQ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 5, 2015 Author as said you can fill and repaint any holes, but if you need an alternative you can get triple monitor stands that are adjustable and all mount and sit on the desk surface: http://www.bit-tech.net/hardware/2011/07/24/xfx-triple-display-monitor-stand-review/1 Sexy stand, Best suggestion so far! I wonder if I could find a similar one with a two tear mounting system. Travis Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 7, 2015 Why doesn't anyone make monitor stands for couches ? I want to sit in my recliner with my feet up while I'm gaming and have a widescreen, high pixel density monitor near my face so i can still read menus, etc. in role playing games or whatever :"( Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 7, 2015 Why doesn't anyone make monitor stands for couches ? I want to sit in my recliner with my feet up while I'm gaming and have a widescreen, high pixel density monitor near my face so i can still read menus, etc. in role playing games or whatever :"( This basically, they do exist but aren't as common: https://www.pinterest.com/pin/468867011176185741/ Updated Modding FAQ Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted June 7, 2015 This basically, they do exist but aren't as common: https://www.pinterest.com/pin/468867011176185741/ That looks awesome ! Thanks dude. Link to comment Share on other sites More sharing options... Link to post Share on other sites More sharing options...
