SSD problem
What clone utility did you use? Looks like you did a sector by sector clone, which is great for an exact copy as it does that well. The downside is that it also clones the drives spec's as well. You should be able to go into the disc management section and increase the size of the larger drive to the full capacity. I would unplug my old drive first before trying anything just to make sure that it will actually boot off of the larger drive. Windows has issues with the same OS install existing on 2 drives. After verifying that the drive will boot and is OK I would increase the size of the larger drive to max. (with the other drive still unplugged.) Then I would suggest that you use a bootable utility to wipe the old drive. (after testing and increasing the size of your larger drive.) Make sure now that your "new larger drive is unplugged and you old drive is plugged in. Do this ONLY after you verify the larger drive's functionality.
