Hello there,
So I was wondering if I can run Far Cry 4 with my FX 6100 and Radeon 6870 (1gb gddr5) 8 gb ram  because I see a lot of ''inconsistency'' about the minimum specs. I don't care about how low I need to run it if I can just play the game I'm alright
Thank you
https://linustechtips.com/topic/378964-far-cry-4-system-requirements/
That gpu may limit you to low quality, but the cpu is the main thing.
See, when I bought Far Cry 4, I ran it first on my old pc, which had a core 2 duo 9300 at 2.5 ghz in it. The game ran like shit even on low.
When I got my new build, same gpu, different cpu, a 4690k. Even at almost medium to high settings the game runs solid at 60 fps.
So it really depends on your cpu honestly, I don't know much about AMD to be honest with you, I've used laptops with their processors before and steered away from them ever since. So you might wanna do a bit of research.
yea...
maybe at 1024x768
I see people playing with 6870 on FHD on high but with 2GB, while some are saying it's laggy as hell so don't want to make false statements but there could be some problems if you want higher setting.
The ability to google properly is a skill of its own.
You're above the minimum, so it will probably work :) you will have to turn down most settings though.
PC SPECS: CPU: Intel Core i7 3770k @4.4GHz - Mobo: Asrock Extreme 4 (Z77) - GPU: MSI GeForce GTX 680 Twin Frozr 2GB - RAM: Crucial Ballistix 2x4GB (8GB) 1600MHz CL8 + 1x8GB - Storage: SSD: Sandisk Extreme II 120GB. HDD: Seagate Barracuda 1TB - PSU: be quiet! Pure Power L8 630W semi modular  - Case: Corsair Obsidian 450D  - OS: Windows 7
Hello there,
Thank you
Your CPU should be fine, and with reasonable settings the GPU should be ok too. Check this guy testing different settings on an i7 + HD 6870 build.
It's a really fun game.
